New mechron... dragging brake
/ New mechron... dragging brake #1
patcopaul
Good Evening All,
Today I took delivery of a new Mechron.
I have to say I'm pleased with the build quality and will give a more complete impression once I have time to form one.
I do have one problem. The mechanical emergency brake seems to be dragging.
How bad does it drag? I can drive the unit without noticeable resistance but after only 1/2 mile or so the disk is extremely hot and I can smell the pads. Not good.
I have examined the disk (it is installed just before the rear differential) and adjusted the linkage. It appears (as it did before I loosed it further) to be adjusted properly.
While the unit is static I can see light between the disk and the pads. When the unit is jacked up I can turn the real wheels by turning the drive shaft. It's not particularly easy to turn the shaft but it does turn.
I didn't get all up and under the thing today as it was raining fairly hard and the light in the shed wasn't the best.
I don't think the problem is the adjustment.
Any ideas?
/ New mechron... dragging brake #2
Did you ever solve this?
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2017 FREIGHTLINER M2 TRASH TRUCK (A67714)
2017 FREIGHTLINER...
1993 Brenner 307 SS Insulated T/A Chemical Tanker Trailer (A68183)
1993 Brenner 307...
1999 Freightliner FL112 Tri-Axle Dump Truck (A66736)
1999 Freightliner...
