New Max series...
/ New Max series... #261
PSUTundra said:
Anyone run the Max 28xl with the Mahindra pallet forks? Would like to get opinions on both the real lift and the use of the implement particularly the ability to use it on the loader and the 3PH.
I have that setup. It is great. The only negative, is the weight of the forks. I think they are 350lbs. As they are rated for 2500lbs capacity, they are over-designed for the max28. However, that has not been a problem for me. Just reduce your lift expectations by the weight of the forks and you will be pleased.
They are made by kodiak, and you could verify weight through them (I haven't). Northern tool also has a set like that, which is where the weight is listed. Once you pay shipping for northern tool, there is no advantage. I bought RFM 60" and PForks through my dealer.
/ New Max series... #262
Well I was more worried about if the 25 would be heavy enough to not be light on the front end with a 5 foot BH on the 3 pt. But I suppose if I left the loader on it would be fine
What do u think?
You would want the loader attached if you have anything heavy on the back. No doubt the Max28 is a little more tractor than the Max25. A little heavier, bigger tires, a little longer, etc. If you are worried (justified or not) that the Max25 is marginal, just get the Max28 and don't sweat it. But either will run a standard duty 5' rotary pretty well.
/ New Max series... #263
Once again thanks for the insight Dave I do appreciate it. It's not at all that I think the Max25 is marginal,on the contrary there's a lot of things I like about the 25 including the Mid PTO. I just want to make sure I get enough tractor this time and not make the same mistake twice.
/ New Max series... #264
I hope to head out to a dealer this week to actually put my hands both a Max 25 and a 28XL. I think that, more than anything will give me a better idea about things.
/ New Max series... #267
It has done everything I have ask of it and sometimes more. I just have to remember that it is a small tractor and try not to exceed the recommend uses. I'm very happy.
/ New Max series... #268
Should be picking up my 28XL w/fel, belly mower and tiller tomorrow! Ready to get off of the '99 model Gravely I've been using and getting the crap beat out of me.
Ls
/ New Max series... #269
Ls
How much did the dealer get out of you for all that? If I go with the Max 28XL that is probably the package I'll choose. May be less the belly mower I keep flip flopping on that aspect. Congrats! I hope you enjoy it!
/ New Max series... #270
Are you that fellar on youtube.
Yes sir. I appreciate everyone that watches. I'm in transition to another store that I think I will really enjoy better so you will see many more youtube videos soon.
/ New Max series... #271
Another Mahindra dealership?
/ New Max series... #275
Bummer, so much for the Don and Bean show! At least you get to stick with Mahindra!
/ New Max series... #276
It was $18,000 for the tractor, fel and mower. Then I added the tiller for $1500, so $19500,... But I did the 0 % so there is the add in and insurance on top of that. Picked it up today but didn't get to operate ( play) much due to other things on the "do" list. Maybe later this weekend!
I went with the belly mower so that my wife could mow should I get stuck out of town for an extended period during mowing season. Figured there would be less chance of something getting taken by a mower hanging off the rear!
Still have a few more attachments to buy. The place is rough in spots and high and low in others. Looking at also getting a box blade and dual edge grader.
/ New Max series... #277
Good looking machine right there! Nothing like getting your new machine only to not be able to play with it. I hope you can fit in some seat time soon!
/ New Max series... #278
Anyone know if there is a suspension set option for the Max 28xl?
/ New Max series... #279
Anyone know of a suspension seat option for the Max 28XL?
/ New Max series... #280
Several aftermarket companies have suspension seats available. The mount is a universal type so it should be an easy install. I have seen them ranging from $250-$500. Just Google "tractor seat suspension kit"
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
Case SV280B (A60462)
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
Deere 333E (A60462)
Deere 333E (A60462)
