New LS, what rpms to operate at
   / New LS, what rpms to operate at #11
Just out of curiosity, what does the manual recommend for operating RPMs?
Alright thats good to hear, i'll try and keep it at 2000rpms for easy use and bump it up if working harder
   / New LS, what rpms to operate at #12
Let's say a guy or gal was hard headed and chose to ignore sound advice to keep RPMs up all the time, preferring to instead run about 1,500 RPM most of the time for a compromise between fuel useage, noise, and available power. What would be the consequence? I expect it would regen more often but why is that a bad thing? Does it decrease the life of the machine? Does the DPF only have a certain number of regens it can handle before it goes titsup? Or is the problem that it would never heat up enough to go into regen at all, thereby clogging up the works and causing premature failure? Or Is it something else entirely?
   / New LS, what rpms to operate at #13
Look at it this way, yes it’s better to run it at 2000 RPMs, but you won’t find a warning in your owner’s manual that says you must.
It will probably just regen more often. Will it shorten the life of the system? I don’t think anyone really knows.
   / New LS, what rpms to operate at #14
The way I was told about engine RPM / Workload of the tractor / Regen intervals is as follows.
The RPM of the engine is determined by the needed workload of the engine/tractor. If your engine is going to be strained or loaded hard at lower RPM's then the engine's exhaust will be dirtier than if the engine is running higher RPM's at the same workload. So by running your engine at lower RPM's and pushing it, it causes the regen time to be sooner than running the same workload it at higher RPM's. If your not really pushing the tractor's engine and just doing minimal work with high RPM's your again going to have sooner regen because your burning more fuel (because of higher RPM). The ideal use of the engine which results in less frequent regen times would be to use the RPM's the job requires, I use my tractor for a bunch of different things, the RPM's vary depending on what I'm doing. So far so good.
   / New LS, what rpms to operate at #15
I see the logic, but I'm not really sure I agree with that 100%. My experience is that when I first got mine and ran it around at lower RPMs, "unloaded" (driving into/out of the woods, moving things around with the pallet forks, etc) the regens occurred more often and seemed more 'harsh'. After I started running it at 2k+ for all activities (when not sitting there idling for a few minutes), the regens were much closer to the 50 hour interval that was advertised, and they were barely noticeable. I haven't noticed an appreciable increase in fuel consumption.
2014 Transcraft Trailer (A55973)
2014 Transcraft...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2016 Peterbilt 337 Corrosive Flammable Liquid Transport Truck (A55973)
2016 Peterbilt 337...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A56435)
1995 Ford F-250...
