New LS Owner
/ New LS Owner #21
LOL, I love the tractor! Didn't mean to sound like I was getting after the LS. It is a workhorse! I know it is the Operator, not the tractor or implements! LOL
/ New LS Owner #22
I wanted to get back to you and let you know that this worked perfectly. I found one of my rat tail files and went to work. Married up the PTO and shaft on shredder and went to work. LOL found out quick how to fix the flats from the mesquite thorns too. I took my back hoe attachment off and now can't get the hydraulic lines reconnected. Any suggestions?
T
With the tractor off move the hydraulic levers back and forth to relieve the line pressure. Same on the BH levers. Line pressure will prevent you from inserting the quick connect fittings.
/ New LS Owner #23
I finally put my operator hat on and thought about the problem. All I had to do was place a rag over the tip of the hose fitting and press the ball bearing in a couple of times. All is good, back hoe on mounted, working, got done what needed to be done today. What a workhorse this little LS is! Love it! HeHe, fun too.
