New low sulfur fuels
   / New low sulfur fuels #1
Strongman
Southeast Michigan
I was talking with a semi-truck driver and how others are now putting additives in with their fuel (some putting in transmission fluid) for engines made prior to 2006 since the new low sulfur diesel fuel doesn't have the same lubrication quality as the high sulfur fuel and are wearing out rings and gaskets. Has anyone heard of this issue? I'm a little concerned about my 2004 Branson 3820. Obviously the number of hours on my Branson is a fraction of a semi, but I would still like to get Branson's opinion on this. Thanks!
   / New low sulfur fuels #2
we visited a 'major' terminal in the Richmond VA area for work and they had a 'lubricity additive' they were adding to the ultra low sulphur diesel.. Im sure that all terminals are doing the same before it leaves for the retail stations.. So there is a problem with lubricity, but it is being addressed.
I always add power service and will continue to do so, and we dont have ULSD in our area yet..
   / New low sulfur fuels #4
Strongman:
There have been quite a few posts in the Oil, Fuel, and Lubricants Forum this year. I have been adding a "double shot" of Power Service (White Bottle) to help with gelling challenges this Winter and will keep adding Power Service to my ULSD fuel for lubricity during the warmer months if they ever come. I suggest you follow the threads by DieselPower. He is quite informative. Jay
   / New low sulfur fuels #5
The new ULSD does have higher sulvent effect than the LSD and even more that HSD. When the LSD came out there were some pump o-ring and hose problems and since the new ULSD came out there have been even more. In older engines it deteriorates the natural rubber compounds used in older o-rings and hoses. Newer engines and replacement hoses and o-rings are made of newer rubber compounds that are resistant to this deterioration.
Adding ATF to the fuel, not in one of my engines. :) It "may" help with lubricity but it will also be more prone to causing deposit problems with injectors and combustion cylinders. The new ULSD fuel does have a lower lubricity level than LSD did. The process that removes sulfur from the fuel also removes other properties that add to the lubricity. Bulk fuel suppliers are adding lubricity additives at the distribution points to help offset this lower level of lubricity. I myself use a fuel additive year round that adds to the lubricity level just for some extra insurance.
   / New low sulfur fuels #6
I tried not to do this but the devil and the klingons made me. It's 1965 and the sky is falling all of our engines are going to go belly up because the government is making us buy unleaded gas. I actually think my ford F250 runs better with the new ultra low diesel.
   / New low sulfur fuels #7
Your F250 may run better on the new ULSD, I don't doubt it. The problem isn't it's performance characteristics, it's effect on long term wear characteristics on injectors and injection pumps is the concern.
   / New low sulfur fuels #8
Two specific questions:
1) Which specific Kubota models does Kubota say are OK for the B5 fuel?
2) Does anybody see anything wrong with using B5 in a Kubota 5030 HSTC for its additional lubricity characteristics above that of ULSD?
Thanks.
   / New low sulfur fuels #9
I've been waiting for all our Kubota's to croak on ULSD since last October when they began feeding on a constant diet of it, so far no problems after a couple of hundred hours of hardcore useage......
How long do we have to wait for the sky to fall?
   / New low sulfur fuels #10
I talked to my supplier and he said that the manufacturer puts the lubrication into the diesel fuel so that you will have the needed lubricity. The foreman at my dealer told me to put a little motor oil into the fuel, if I was concerned about it. So far I have used Power Service and that is all. I would suggest talking to one's dealer about fuels, oil etc.
I use the red offroad diesel in my NH tractor.
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
16ft 3in Box Blade (A51573)
16ft 3in Box Blade...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
RHINO X1406 LOT NUMBER 64 (A53084)
RHINO X1406 LOT...
