NEW log splitter BX22 WOES
   / NEW log splitter BX22 WOES #1
copperhead1967
greensburg PA
kubota BX22, Cub ZForce S 48 inch deck
I posted this in the Hydro section also.
I just purchased a 3PH mounted log splitter, when I hooked it up to my BX22 it loads the rest of the hydro system down. I put in fluid, bled the lines by cycling the loader, 3PH and finally the splitter cylinder. The first time it moved at a moderate pace. Now it crawls at a snails pace. The FEL control valve makes a whining sound and the FEL functions erraticly. The 3PH won't move up . I took off the splitter lines and hooked the tractor back into itself. Everything worked great. I have 1/4 inch hoses on my tractor and the splitter is plumbed with 1/2 inch lines. I picked up a handful of fitting and bushing with the help of the guy at the local shop got everything together. Could a bad quick connect be the problem? It seems like a flow problem in the splitter. The splitter is rated at the flow rate for my tractor. Any ides where to start?
   / NEW log splitter BX22 WOES #2
A couple culprits may be mess'n up the works.
1) You must be using the BH connection, are the connectors to the splitter valve clearly marked "in" & "out"? If not you may try reversing the connections to the splitter valve.
I'm not sure which connector on the BX22 is "in" & "out" but I suspect the female connector is the power out and the male is the power return.
2) the splitter valve may not be a power beyond type, i.e. it isn't routing hydraulic power through the valve block back to the tractor when the valve(s) are in neutral. Since the hydraulics are in series, a restriction in one effects them all.
3) there may be a restriction in your connections.
Good luck
Volfant,
I swapped the lines around already and it reversed the operation. The valve has a forward, nuetral and return position. I plumbed a 2000 PSI guage on the IN side of the splitter valve with a T fitting. it shows no pressure when open(forward), and holds at about 1600 psi when fully retracted. This was the first few cycles. Now the reading is around 1000psi when retracted.
I'm thinking a bad coupler. I'll take some pix of the set up and the valve. I'm also going to contact the manufacturer to see if they have any ideas. Seems they wouldn't make a splitter without the right type of valve.
here's the link
Ramsplitter Log Splitter Model 3PT Attachment, the Toughest Log Splitter on the Market
   / NEW log splitter BX22 WOES #4
I'm thinking a bad coupler. I'm thinking the same.
I'm also going to contact the manufacturer to see if they have any ideas. I would've done that first (?)
I agree, after looking at the website these splitters are pretty application-specific. Nice looking unit, btw.
It always cracks me up to see "Add to Cart" on things like this. #1, as if it would fit in any mass-produced shopping cart known to man, and #2 not exactly an "impulse buy" akin to batteries or chapstick :)
Just thought I'd run it by the folks here first:)
Don't think the manufacturer would have anyone answering phones after 11PM when I got done messing with the tractor.
Hopefully the unit will work as good as it looks when I get the bugs worked out. It will be nice to cut the logs, split them, load them out and stack all in one day!
I'm going to look into some more when I get home from work. I'll try to call the manufacturer today if I get a chance, I'm thinking they have had to answer this one before possibly.
   / NEW log splitter BX22 WOES #6
This might be a general flow issue in that the BX flow rate is not high enough to run a splitter at a good pace. I've had one on my BX2230 and it would never run at a pace equal to that of a cheapo one from TSC with a 5hp engine on it.
   / NEW log splitter BX22 WOES #7
Just a reminder, please do not doublepost. It forces you to watch 2 threads and people to reply in 2 threads. The thread in the Hydro section has been closed.
   / NEW log splitter BX22 WOES #8
Not familiar with the Kubota system, but could it have something to do with a closed system versus an open system? Which would steer you back to which type of valve would go on the splitter.
Sorry about the double posting. Was kind of helpful though:eek:
I going to take the input line and output line off the splitter valve and connect them together, pretty much as suggested prior. This will check all my plumbing work and eliminate it down to the 4way and the cylinder itself.
I think that it was functioning ok as I was priming it up with the fluid, then it got wacky. I'm thinking some junk got pushed around in the hoses and is restricting the flow.
   / NEW log splitter BX22 WOES #10
That's because the cheapo log splitter uses a two stage pump. Tractor doesn't have that. Most of the travel of a log splitter ram can be handled by the low-pressure, high-volume side of the two stage pump.
Some things are meant for each other:
Log splitters and two stage hydraulic pumps
Bird dogs and shotguns
Pancakes and syrup
Bill and Hillary
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
28013 (A50322)
28013 (A50322)
