New linkage for 1450 loader
   / New linkage for 1450 loader #11
That looks good. Your bucket bracket is different than mine. Did you modify that as well?? Mine is more of a triangle with not as much room to move around at the top. Now please give the distances you have those 3 holes apart and the thickness of the metal. Thanks bcs
At full height and full dump my bucket edge is close to 6" lower than the rear of the bucket. So I should be fine.
</font><font color="blue" class="small">( Your bucket bracket is different than mine. Did you modify that as well?? )</font>
No, I have the skid steer style quick attach that my pins go to instead of the bucket.
The linkage is 5/16" steel
The bucket pins are 3" higher
For the linkage, the lower 2 holes and linkage is the same with the very top (3rd pin ) 3" higher.
I needed to buy 2 pins Part#0550-3013
2 dust covers Part#0541-3002
2 O-rings Part#0520-3000
2 bolts Part#0545-2024
You will also need to add new curl and dump bucket stops
DEUTZ MARATHON...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
