New leads for the old AC-225S
   / New leads for the old AC-225S #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
I picked up an old Lincoln AC-225-S a while back & been using it for a few small projects. I have finally gotten around to replacing what appeared the original leads. I had (re-)patched them in multiple places with self-fusing tape w/an over-wrap of vinyl tape before using it but the old stuff really needed replacing. I picked up new lead wire from WeldingSupply.com. I went with 4 AWG as that appeared to be what was there originally & each lead is only about 18'. I also decided to do a small upgrade & added Dinse style panel connect sockets, with mating connectors on the leads. The Dinse connectors came from Amazon.com. If I need heavier/longer leads, with the disconnects it will be easy to do a swap out.
While I had it open, I dosed the switch contacts with DeoxIT-D contact cleaner & worked the switch around all positions a few times to help clean & lube them up a bit.
   / New leads for the old AC-225S #2
Nice looking upgrade ! Had to open mine up a few years ago and lube the fan as it was starting to get noisy.
   / New leads for the old AC-225S #3
Nice upgrade!
How much did you pay for the leads
I bought 40' of 4 awg at weldingsupply.com for $0.80/ft & 8 L-26 lugs for $0.75 each (I reserved about 4' of cable & 4 lugs for doing a battery disconnect on the little gator). Shipping was $17.47 & the packge arrived in 2 days. The DKZ10-25 200A Euro Style Cable Connectors were $6.99/set (male cord + female panel) on Amazon.
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2014 716PT Homesteader 7'x16' Box Trailer (A52384)
2014 716PT...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
