Rake New Landscape Rake
/ New Landscape Rake #1
TxBilly
Columbus,Texas
Kubota B2400
I have been finishing the area around my house for seeding a lawn and after doing FEL and box blade work, needed to really finish it. Got a landscape rake with guage wheels and it did a great job. Here it is attached to my B2400.
A closer view of the rake.
/ New Landscape Rake #3
Looks like a nice little rake,On a nice little tractor/w3tcompact/icons/smile.gif
/ New Landscape Rake #4
Looks like a very nice outfit you have there. That rake should bring you many yrs of bliss :)
/ New Landscape Rake #5
Bill,
<font color=blue>Got a landscape rake with guage wheels </font color=blue>
Do you find the wheels necessary in the finishing work that you do? I just bought a Frontier LR1172 medium duty rake for a JD4710. I had the option of going with gauge wheels at $250 extra. I couldn't justify the expense on this. Never have known anyone using these wheels who couldn't do the same work without them. Your thoughts or anyone's thoughts on this please.
Regards,
Bob Ancar
Cambridge, NY
/ New Landscape Rake #6
My experience is that gauge wheels make it a whole lot easier to do a good job with a landscape rake. Without them the rake tends to either dig in too much or come completely out of the ground when the surface is unlevel. You are constantly moving the hitch position to try to compensate for this as much as possible. Although some hitch position adjustment is required when a rake has gauge wheels, it is not nearly as much as that required with wheeless rakes. Most rakes are sold without wheels as standard equipment in order to keep the price as low a possible. There have been several threads in the past discussing this issue. I believe it was Von who reported on the improvement he found after equipping his rake with wheels. He has posted several photos showing his design and how the whole rake folds up neatly for storage.
Bob
I found that the wheels allowed me to "level" the dirt better. You can put the 3pt in float and the wheels will keep it at the height you want based on how you have them adjusted and will keep it level from side to side. I don't know if I could have gotten the results I wanted without them. Attached is a picture of some of the area.
/ New Landscape Rake #8
Thanks Jack and Bill.
OK, I think you convinced me that the wheels could add beneficial results with the finishing work one tries to do. But, I guess another related question I have and it pertains to Jack's comment on using the wheels and rake on uneven terrain conditions. Do you think a tractor's top and tilt would be able to compensate somewhat for the lack of wheels? I ordered my tractor with the top and tilt kit as this would help me in the use of other implements. With the landscape rake, I thought about the situation of using the rake on uneven terrain, and I have plenty of this, and for the need to adjust the links to avoid digging too deeply and maybe doing damage to the rake's tines. My thinking though was I could avoid these potential difficulties by using the tractor's top and tilt functions and manually raise or lower the 3ph when needed to compensate for degree changes in terrain. Of course, this would require a bit more time in any job I do as I would have to pay much closer attention to changes in terrain conditions than if I had the wheels but I thought I could do this, save the $250 I would have to spend for wheels, and use it on something else instead. While I ordered the rake without wheels, I'm trying to get info from the dealer on whether I could purchase the wheels at a later date if I think I really need them.
Thanks for your insight.
Bob
/ New Landscape Rake #9
Bob, I just made my own set for my rake. Got two wheels and tires from Harbor freight for $12.00. And welded up the rest from scrap metal I had laying around. Attached is a photo of them.
/ New Landscape Rake #10
Top-n-tilt is useful for many things, but I don't think it would be very practical for controlling the rake to achieve levelness. You could tilt it to one side to clean out a ditch just as you would with a rear blade or box scraper. Most of my experiences with a rake have been in final stages of soil finishing in preparation for seeding or sodding. You make several passes in different directions to comb out small stones and sticks and produce a level surface just as you would with a hand rake in preparing a garden seedbed. During the first pass or two, the ground the tractor drives over is not level. Gauge wheels on the rake are close to the tines and help keep the rake as level as possible independent of what the tractor is doing. Note that these wheels run over a surface that has already been smoothed by the rake tines so they don't encounter as many bumps. I'm sure the wheels can be ordered any time as an accessory. My bet is that you will ultimately decide they are worth the cost.
/ New Landscape Rake #11
Bob, The wheels make the rake work much easier. The effort required to make an area with high and low spots smooth without wheels is considerable. I don't think top and tilt would make much difference. Without the wheels the 3pt height has to be constantly adjusted to account for the uneven terrain that the tractor wheels are driving over. A small bump under the rear tractor wheels results in a larger movement of the rake because it is cantilevered off the back end. Without constant adjustment the bumps will actually get bigger when using the rake. With the wheels all that is required is adjusting the wheel hight relative to the teeth and then just drop the rake and go. No on the fly adjustments are necessary. The wheels roll on the smooth surface behind the rake and remove the bumps. Adjusting the wheel to tooth height can be done with the top link, so the top and tilt would work great with wheels.
About 4 years ago I made my own wheels for the rake after encoutering the difficulties above. You can see the wheels at:
http://www.mgsweb.com/tractor/hacker/rake.htm
Andy
/ New Landscape Rake #13
Guys, how much for an average LS rake with wheels? Not the best, not the worst. thanks, bw
/ New Landscape Rake #14
bw, Yes the wheels have about 4" of adjustment up and down by moving spacers on caster shaft. In the photo they are all the way up.
/ New Landscape Rake #15
Brett,
I payed $400 for a used (rental unit) Landpride LR1572 ( 6' ) rake. New, I found it to be between $700 / $800
I also purchased a New set of guage wheels for it for $240
I have found the Landpride brand to be very well made and plenty rugged.
/ New Landscape Rake #16
Brett, My rake is 6 foot and was a little over $400 without wheels. It is built like a tank, I have seen some pretty light weight rakes that may cost less and brand name ones may cost more. Rakes are more expensive than rear blades for the same level of quality. I spent about $50 in materials to make the wheels, if you buy them they cost a few hundred or more. The wheels I used, have ball bearing swivels with a grease fitting, ball bearing axles, and the tires are air filled and replaceable.
My wheel height is adjustable about 8 inches. I used square pipe for the wheel posts and frame. The wheel posts slide inside a larger section of square pipe on the frame and I welded a nut on the side of that. I used some 1/4" x 1" flat stock welded to the head of a bolt to make it so no tools are needed to adjust the wheels up and down. Even though the height is fully adjustable this way, I usually do the final adjustments with the top link once I start driving and see how big a bite the rake is taking.
Andy
Brett
My rake is made by bush hog. It is a 72" rake and with the wheels were $672. The wheels added about 200 to the total. It has 5 positions as pulling, swings around and has 3 positions with the rake tines in "reverse". You can swing it a full 360 without hitting the tractor in any way. Weight is about 250 lbs.
Bill
/ New Landscape Rake #18
Rake sure makes projects a lot easier around the home stead,also in the woods cleaning up...just becareful not to snag the garden hose. /w3tcompact/icons/eyes.gif
/ New Landscape Rake #19
Thomas,
Couldn't help but notice the Garden Hose comment /w3tcompact/icons/hmm.gif Was this a personal experience ? Inquiring minds want to know, C'mon, spill the beans, Tell us what you did! Where all Family here. I am sure that NOBODY will give you any grief over it. Trust us ! /w3tcompact/icons/eyes.gif /w3tcompact/icons/wink.gif
/ New Landscape Rake #20
All I'm going to say is..when I drop the rake close to a object I check before moving forward /w3tcompact/icons/eyes.gifand the male end of the silcox not a strong as one thinks. /w3tcompact/icons/shocked.gif/w3tcompact/icons/wink.gif
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
2019 Big Tex T/A 16FT Utility Dump Trailer (A59230)
2019 Big Tex T/A...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
