New Lacing on round baler belts:
   / New Lacing on round baler belts: #1
hapec12
Michigan
Kubota Grand L4060.
How much can belts be shortened to install new lacing? I have a Case IH 8420- 4.8X364 inch belts. They have been shortened once already,now measuring 361.5 to 362.75. I was told you have 8 inches to play with. Any help will be appreciated.
   / New Lacing on round baler belts: #2
I have a 5530 hesston which is the same baler, my manual says minimum of 362, i think i was only able to get around 360 and some change out of mine when i put new lacing in this spring. Local dealer said that should be ok, so i went with it. It seems ok and worked just fine, i also put the pins in and drop the gate to relieve the tension on the belts when im not using it. Hopefully that'll help the pins and laces last a little longer and not tear out.
   / New Lacing on round baler belts: #3
You will be fine the belts have had ware on them already.. two splices is nothing as long as its done right.. you can also adjust belt tension if it seems to be to tight.
   / New Lacing on round baler belts: #4
If you are worrying about length, you can always install a longer splice than the material you removed. I've run 2 splices and numerous singles. None of them the same length. I gauge my belts by pushing on them at the rear of the baler with the gate shut. I use the level monitors to see where the belt should be and one by one push on them to see if they match it. If off a little I don't worry about it. I work hard for a square bale but if I don't get it, I don't get it. I probably do more to screw it up than a mis-sized belt would. Course with irregular fields and irregular growth, I'm not completely to blame.
   / New Lacing on round baler belts: #5
Mark
I'll bet level bales are a lot easier for you to make now than when you 1st started rd baling several yrs back??:drink:
   / New Lacing on round baler belts: #6
Yes sir, thanks to you. Here's a couple of pictures of that crop:
   / New Lacing on round baler belts: #7
Your bales look much better than my neighbor's bales who has been custom baling for the last few yrs. I'm glad I could help you.Jim
   / New Lacing on round baler belts: #8
Thanks. Coming from a custom guy like yourself, that IS a compliment.
2016 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2016 VOLVO VNM...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2003 Big Tex 10PI...
2014 Peterbilt 388 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2014 Peterbilt 388...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
2020 DRAGON ESP...
