New L6060 Top and Tilt and Euro Style Hook-end Quick Hitch
   / New L6060 Top and Tilt and Euro Style Hook-end Quick Hitch
I cannot find those hooks and balls on the AgriSupply website. Can you put up a link? Thank you.
It’s Agristoreusa.com and if you search for these, you’ll find whatI bought. Sorry on my cellphone and not very user friendly to link.
Cat. 2/1 Lower Link Quick Release
Cat. 2 Top Link Hitch
Category 1 Lower Link Ball
Category 2 Top Link Rapid
What I didnt know and wished I did is the ball diameter is the same for Cat 1 or 2 balls the the pin diameter is different. So the top link is a Cat 2 hook end so I ordered Cat 2 balls. Nearly all my attachments are Cat 1. So I had to put sleeves in each of the top link balls to reduce from Cat 2 to Cat 1. I bought a couple of Cat 1 toplink ballks from TSP and Rural King and they work fine. Should have just got Cat 1 balls to begin with but didnt know.
Also for the 3 pt hook ends if I had to do it again I would just buy the hook ends not this kit. I didnt any of the “extras” from the kit other than the extra balls it comes with. To be honest not sure what some of its for because you dont get any instructions.
The hook ends themselves were out of stock at the time so I had to get the kit.
Also, wanted to note, may have already, but Brians prices for these were quite a bit less than Agristoreusa.. and he can do the cutting and welding professionally.
Ive been fabricating most my life but getting the cut angle right and then lining it all up to weld wasnt the easiest thing in the world and you want to get that angle right. Mine arent exact but close enough that I havent had any problems and they work great.
   / New L6060 Top and Tilt and Euro Style Hook-end Quick Hitch #23
One thing to consider is the size of the hook.
If your tractor is Cat 1 and you only use Cat 1 implements, then get the Cat 1 Hooks. If you get the Cat 2/1 hooks, the hook can be too big to fit on some Cat 1 implements.
For instance, Cat 1 hook uses a 44 mm Ball with a 7/8" hole. You get any 44 mm balls to work with Cat 2 implements. I did it but machined my own balls and just made the hole bigger.
The Cat 2 hook uses a 56 mm ball with a 1 1/8" but you can also buy a 56 mm ball with a 7/8" hole or even a ball with both hole dimensions. The catch with using the Cat 2/1 hook on Cat 1 tractors is that the hook is huge versus the Cat 1 one.
   / New L6060 Top and Tilt and Euro Style Hook-end Quick Hitch #24
Useful info. Thx. My lower links are Cat 1 7/8" and all the implements have 7/8" pins.
All great info. The only Cat 1 implement I have issue with is an old Ford disc from the 1950s and it rubs a little but still works. I agree though that if you have clearance issues the smaller hooks would be useful. Not sure if the 44mm balls but the ones for the Cat2/1 are readily available at Tractor Supply and Rural King which is a big plus for me.
2017 Jeep Wrangler Unlimited Sport (MPV), VIN # 1C4BJWDG5HL577343 (A57453)
2017 Jeep Wrangler...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
Deere 333G (A53317)
Deere 333G (A53317)
2022 John Deere 1025R (A53317)
2022 John Deere...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A56859)
2009 Mariah SC23...
