Buying Advice New L3560 Limited and Standard Versions
   / New L3560 Limited and Standard Versions #171
How much room do you have under the seat? Could you add an air bag and air it up to the pretty you need and cap it off?
   / New L3560 Limited and Standard Versions #172
Glad you are enjoying the new tractor. I would love to replace the seat in my tractor, but for the price, not going to happen.
The fogging is an issue, may sure you turn off the recirculating, that seemed to help my fogging issue.
   / New L3560 Limited and Standard Versions #174
Awesome machine and it's the one I want to eventually get once i utilize my L3301 to clear brush within 40 acres of trees. The tractor gets beat up (no damage yet) and I will most likely utilize a cab tractor to mow with instead of my zero turn since I'm mowing about 3 acres. The disadvantage is the weight vs the zero turn but so be it.
What is your tractor parked on? Doesn't look like concrete.
   / New L3560 Limited and Standard Versions #175
Looks like black top to me (asphalt).
   / New L3560 Limited and Standard Versions #176
Not familiar with the tractor so this might not apply.
In the Winter leave the AC on. Then adjust the heat to the temp you want. The AC will dry the air and help dramatically with fog on the inside of the windows.
In your car/truck the AC compressor is running anytime you are blowing heat onto the windows.
   / New L3560 Limited and Standard Versions #177
No I was thinking about something off a truck. I think they can be compressed with hand pressure empty so with a low pressure they should be able to reach the desired strength. IMG_7972.JPG
   / New L3560 Limited and Standard Versions #179
Yeah, I thought about the truck helper bags for the seat. I've yet to pull the seat and take it apart to see what it looks like inside. It has a rubber accordion dust shield around it so you can't see the inner workings.
I do leave the A/C on and it makes no difference. To be honest, most A/C compressors won't run below a certain temp anyway to protect the system, even with the A/C light on. Dew points are low in very cold weather so running the A/C with heat isn't going to melt ice off the glass. I don't use recirculating.
If you're talking about my picture, that's just an asphalt parking lot. I used the tractor to clean up a tree that fell nearby shortly after I got in and just snapped the picture at that point.
   / New L3560 Limited and Standard Versions #180
Sounds like your enjoying it and besides the seat sounds like the right fit for your needs. I can see where the seat could be an issue. I weigh about 190 and have mine pretty much cranked up the whole way. So far the L3560 LE has met my needs well.
2014 JOHN DEERE 250D SERIES II OFF ROAD DUMP TRUCK (A52705)
2014 JOHN DEERE...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
30pc. 16ft.x 3ft. Black Metal Roof Panels (A55758)
30pc. 16ft.x 3ft...
Kubota BX2230D (A47384)
Kubota BX2230D...
Sterling AT (A55301)
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A54865)
IMPORTANT PLEASE...
