New L2501 Owner
   / New L2501 Owner #1
jweedz
Brooklyn, WI
Kubota L2501
After countless hours of TBN research, I finally pulled the trigger on a new L2501 a few months ago, and had it delivered last month. Will be used mostly for maintenance of a 1,000' driveway, as well as various cleanup chores around the property and whatever else I can justify doing with it (getting the mail/etc :laughing:). So far, really liking this machine!
   / New L2501 Owner #3
I have basically the same setup with the front remotes on my L3700 and the LPGS on the rear. Be careful with the skids on the rear scraper. The front leading edge can wear pretty fast if the LP is not laying perfectly flat.
   / New L2501 Owner #4
Nice looking tractor ..........:thumbsup:
   / New L2501 Owner #5
Your bones and muscles will be thanking you in years to come for purchasing setup. :thumbsup:
   / New L2501 Owner #6
Congrats on your new machine :cool2:, and welcome to TBN! I suspect you will be amazed at how many things you will find to use it on and then wonder how you lived without it. Enjoy!
   / New L2501 Owner
Good info, thank you!
   / New L2501 Owner #8
Wise choice;we have a similar sized(L3000DT) and constantly amazed what that little tractor can do.
   / New L2501 Owner #9
Great tractor you bought. Think about wheel weights, even with loaded tires. Did that with my 3301 and it made a world of difference in the stability. Enjoy!
   / New L2501 Owner #10
The economy Ls aren't really safe lifting heavy on the loader without loaded tires. Even if you have heavy ballast on the 3pt.
It took me a while to learn my former L3200 had a loader that could write cheques the rest of the machine couldn't cash. Every machine has a weak point. In this case it's a lack of weight & ballast.
The back of the barn has a pair of pallet fork sized holes because a gate (200lbs?) On the pallet forks while in 2wd was to much. Proper ballast, or loaded tires or being in 4wd would have been fine. Back end came off the ground moving "1200lbs" square bales. Had a rotary cutter on with 100-200lbs of junk stacked on the back for extra ballast. Forget if that was before or after I got the tires loaded. Think it was after.
Its
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
FORD COBRA REPLICA RACING CAR (A52576)
FORD COBRA REPLICA...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
BESTWAY AG VSK50 LOT NUMBER 104 (A53084)
BESTWAY AG VSK50...
