New Kubota with DPF Filter
   / New Kubota with DPF Filter
Well, my new Kubota ZD1511-72 attempted it's first regen at 10.6 hrs on the meter yesterday and failed. First, the amber REGEN indicator came on just after starting to mow grass. Then the second amber indicator came on, then the red engine indicator came on and the engine stopped with the alarm chirping. Engine would not start (would not turn). Got the owners manual out and it said to contact your dealer. Called the dealer and they responded immediately by sending a tech out. The tech looked for a diagnostic code but there was none. By this time it was about 45 minutes after engine had shut down and the red engine light was now off. So the tech started the engine and pressed the Park Regen button to complete the regen process. The engine ran at max rpms until the hour meter hit 11.0 hrs (approx 24 minutes) and the Regen indicator went off. Mowed with the machine another 3 hrs w/o incident. The tech is going to contact Kubota to see what may be the cause for regen malfunction. Kudos to the Kubota dealer tech support for coming out immediately, but needless to say, I wasn't too happy. Hopefully, it never happens again.
Cancelled -- duplicate
   / New Kubota with DPF Filter #63
I don't really want the "intellipanel" since that just adds more electrical complications, but it would be nice to have a light indicating that a regen will occur soon. What should be available on any tractor is a regen-on-demand that you can activate once it's close to needing a regen so you can make it happen at a more convenient time.
We have enough problems with the cancel button and customers never letting letting their machines complete a regen and then calling upset because now their machine is derated and a tech has to come out to reset the soot level because it's a 4 or 5 and perform a manual regen. Giving them the option of having to actually turn it on when it's time for a regen would make things worse. Kubota more or less tried this but went to an automatic system (granted there was no regen soon warning) but the customers just left the regen turned off which created obvious problems. Yes, there is a small percentage of the world that finds it neccesary to track and log every regen but they are a very very small percentage.
Brian
   / New Kubota with DPF Filter #64
My skid steer and my small tractor have the DPF on them. No problems so far but I really don't see how these are more beneficial to the environment. I run those machines at a higher RPM to try and limit the soot build up which burns more fuel. And then the regeneration process burns more fuel to clear out the soot. Seems like burning more fuel would be worse for the environment to me. Plus it is annoying if the regeneration cycle comes on right at about the time you are done with your job and then you have to stay on the machine for an extra ten minutes just to go through the process. And burn more fuel!
My sentiments exactly. I don't blame Kubota, John Deere, Mahindra, or whoever else. It's the EPA going too far in my opinion, especially on these smaller diesel engines that only run a short period of time mowing grass (couple hrs per week during summer) and then the engines are so small that pollution from them are sub fraction of total environmental pollutants. In the end, I suspect something better will come along eventually like what happened with gasoline engines, i.e., cleaner burning fuel, better efficiency, and etc.
   / New Kubota with DPF Filter #66
Brian
I'm not talking about having to turn it on when it's time like the original Kubota system, I'm talking about a way to tell it to start a regen once it gets to 80% or 90% or some limit where you're about an hour from an automatic regen. For example, you are nearing finishing some mowing or heavy pulling work and you see that it gets to that amount. When you finish the current job you're going to be doing short light duty jobs or for some other reason you don't want a regen to happen then, so you tell it to do a regen now, then you're good for a while. Basically giving a range of time when you CAN do a regen, but when it gets to the end of that time it's going to automatically regen.
UPDATE: The tech returned today to look for a diagnostic code using his laptop and found two codes. Both indicate excessive exhaust temperature during the first Regen. Kubota region support rep said he has heard of a few other ZD1511 mowers doing the exact same during the first Regen -- no more problems after the first Regen. Hope mine is in that bucket.
   / New Kubota with DPF Filter #68
Seems like running at higher RPM would burn more fuel but my L3901 seems to use less or same amount of fuel than my other F, L and B Kubotas. I get and have always gotten about an hour per gallon on almost all of my Kubotas under work load. I have no explanation other than several years of personal experience with actual hands on use of the machines and can't provide a theoretical explanation which so many people prefer over actual experience. :confused3:
   / New Kubota with DPF Filter #69
Gassers have to feed in air & fuel at the correct stoichiometric rate, so more air = more fuel. Hence a throttle (look up alternate definitions of the word) to literally strangle the air supply to the engine for lower RPMs. More RPM = more fuel.
A diesel on the other hand always has an unrestricted air intake. The govoner on the fuel pump tells the fuel pump how much to spray per shot to maintain the set RPM. Higher RPM at no load uses insignificantly more fuel than lower RPM. So the diesels don't use much more fuel at no load regardless of a low or high RPM setting. Probably a hair more wear & definitely more noise, but no fuel guzzling linked to RPMs like a gasoline engine.
   / New Kubota with DPF Filter #70
Sunny,
How was the 1511 performance other than the DPF problems? I looked at buying the 1511 but instead went with the 1211-72. So far I have been happy with the 1211 - plenty of power and speed - it cuts better than the old ZD28. When I drove the 1511 I could hear the turbo singing and it sounded like power :) but I thought it was not as quick as the ZD1211 thu, just a little less responsive, definitely heavier.
Have you cut any really high grass, mowed on steep inclines or other situations where the 31HP+turbo would be useful?
Thanks -David
2024 ArmorLite Aluminum End Dump Trailer (A55315)
2024 ArmorLite...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
