Mowing New Kubota questions
   / New Kubota questions #1
cedarstump
SC
Kubota M7060
Got a new M7060 and was bushhoging yesterday. Can i use the shuttle shift at pto speeds. I have the 12 speed and seem to be comfortable bush hogging in 6th gear going about 4.5mph. Is that too fast to use the shuttle shift to back up? Also did first regen at 17 hours. That seem to be early for a regen.
   / New Kubota questions #2
Not if you slow your ground speed to stop or close to it, we use our M8540HDC and have since purchase that way.
   / New Kubota questions #3
I believe the manual states you can shuttle shift any time under 5 mph. Check your manual.
   / New Kubota questions #4
Full throttle is not advisable on any unit at any speed.
   / New Kubota questions #5
I run my tractor at around 2000 when using the grapple. As long as I shift at or near full stop - no problems.
   / New Kubota questions #6
Move to neutral let the tractor slow then move reverse
   / New Kubota questions #7
This has been my experience.
Thanks to all.
   / New Kubota questions #9
All I know is, when I per random mix up the turn signal with the reverser, it's going to kill the engine at full speed.
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
Mini John Deere Truck (A55853)
Mini John Deere...
Hose Reel (A55758)
Hose Reel (A55758)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2018 Jeep Grand Cherokee SUV (A55853)
2018 Jeep Grand...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
