Mowing New Kubota questions
   / New Kubota questions #1
cedarstump
SC
Kubota M7060
Got a new M7060 and was bushhoging yesterday. Can i use the shuttle shift at pto speeds. I have the 12 speed and seem to be comfortable bush hogging in 6th gear going about 4.5mph. Is that too fast to use the shuttle shift to back up? Also did first regen at 17 hours. That seem to be early for a regen.
   / New Kubota questions #2
Not if you slow your ground speed to stop or close to it, we use our M8540HDC and have since purchase that way.
   / New Kubota questions #3
I believe the manual states you can shuttle shift any time under 5 mph. Check your manual.
   / New Kubota questions #4
Full throttle is not advisable on any unit at any speed.
   / New Kubota questions #5
I run my tractor at around 2000 when using the grapple. As long as I shift at or near full stop - no problems.
   / New Kubota questions #6
Move to neutral let the tractor slow then move reverse
   / New Kubota questions #7
This has been my experience.
Thanks to all.
   / New Kubota questions #9
All I know is, when I per random mix up the turn signal with the reverser, it's going to kill the engine at full speed.
2018 MDB T5E MDB DISC MOWER (A51243)
2018 MDB T5E MDB...
AGT drum mulcher SSFM81 Attachment (A50322)
AGT drum mulcher...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2019 PRINOTH PANTHER T14R CRAWLER (A51242)
2019 PRINOTH...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
