New Kubota M5140 owner
/ New Kubota M5140 owner #21
Must be no mud in Tennessee.. we've got some extra you could have. Like eTexas said, you could shift the rear tires to get a bit wider stance, which makes it more stable on hills. It's a pig of a job, but worth the time.
Nice looking machine, it's amazing how much work gets done in a short time without breaking a sweat.
Sean
/ New Kubota M5140 owner #22
My wife and I are in the same boat as you. We bought a place with 40 acres that hasnt been cared for in a while. We went with the 5140 as well. It hasnt even been delivered yet. Looking forward to beating the jungle back. Interested to see other comments on how this tractor performs.
This seems like a good time for an update. I'm about 30 engine hours in. I'm surprised how long the engine hours last me actually. I've worked with it almost every other weekend, for 2 months now. I gues they've been relatively sporadic hours though. I've had to get off and chainsaw for a while every now and then so its not constant running.
I've made my share of newby mistakes. Luckily none have been expensive.
1. First thing I did clearing trees with the bucket was a tree stalk split and went over my bucket and into the grill screen. Luckily it went back to looking brand new with pliers and some gentle hammering.
2. 2nd thing I did, was I was bushogging up and down hills going backward down them and forward up them. One of my hills is extremely steep so this is the only option. I was mowing around trees that were too large for the rotary cutter so I could go back and chainsaw the big trees later. Well two of the trees were closer together than I thought and I bent the deck on my 6" rotary cutter just enough for the blade to hit one side. I shut it off in a hurry after "BAM BAM BAM BAM". Luckily I got that one fixed with a sledge hammer and an acetylene torch and half a saturday. It was not easy work, but straight forward and it works just fine now.
3. One day I was pushing over small trees and mowing them when I lost traction (was on a slope). I made the mistake of trying to back up with a small tree bent over under the tractor and a limb grabbed my fuel line and broke a small fuel line fitting. the tractor emptied itself of gas and I had to replace the fitting ($1.50) and bleed the fuel line of air. I had never done anything like any of that before so it was a learning experience the 1st time. Wasn't too hard in restrospect, but it took me much longer to figure out than maybe it should have. I had to read up on air locks, diesel engines and all that.
4. As I was mowing one of my properties for the first time, i mowed over a sprinkler head hidden under the grass and brush (this is a huge sprinkler head. it was designed to irrigate a motocross track.) and then drove over it on another pass after my mower blade had sharpened the broken stem. It popped a huge hole in my rear tire. Luckily I got it driven to the roadside before it totally lost all air. One of my neighbors took it to get it repaired for me. Luckily they were able to boot it so it only ran me about 200 dollars.
5. last thing I did was snap one of my hazard lights off with a tree branch. when I was pushing over some 3 inch trees and rotary cutting them. Some super glue put that one back fine it seems like.
The common thread seems to be that clearing land and dealing with trees is very very tough on the tractor and extra care has to be taken. Going slow and cautiously is necessary. I've developed the practice of stopping every hour or so even when things are going well and looking under the tractor and looking at connections and fittings for problems. Good news is I'm almost done with a lot of the tree clearing I wanted to do. I have a fair bit left to do on some dirt moving, but will need to spring for some new tools like a yardbox before I can really start on that too much.
/ New Kubota M5140 owner #25
Heck, I still have those issues that plague you after 40 years doing this stuff! Still, there is something very satisfying about cleaning up an old and often misused piece of land. For small tractors it's hard to beat a Kubota. Particularly due to their dealer network, it is really good and getting parts aren't really a problem.
Well that makes me feel better. Thanks KYDan
/ New Kubota M5140 owner #27
Sounds like you have had your share of nicks and scrapes. Anytime you are dealing with trees of any size, there is an element of danger involved. Fortunatley I only have about 10 acres or so that is really overgrown with trees that are 3-4 inches in diameter. It is somewhat steep as well. A good portion of our land has had hay harvested off of it in the past so it is mostly just overgrown grass. And we also have a couple acres of briar patch. Probably dreading clearing that the most. Will let you know how it goes. I should take delivery of the tractor before the weekend. Am ready to get to work. Stay safe.
/ New Kubota M5140 owner #29
Congrats UTCenturion, you are going to love it. I bought a used, low hour model 5040 w/ FEL last October. About all I have done with it so far is mow some pasture - it handles a 7' 3pt. rotary cutter w/ ease. I really like the features it has over the standard MX series.
/ New Kubota M5140 owner #30
Took delivery of my 5140 on Wednesday at about noon. Have managed to put about eight hours on it in the past three days in this crazy, cold weather. I love this tractor. I changed my mind on the 8 foot dual spindle cutter and went with the 7 foot single (3 pts) with a little beefier gearbox. (Land Pride model 1884) Some of my land is pretty overgrown so I thought a little extra heft wouldn't hurt. Tractor handles it with no problem at all. Uphill, downhill, doesn't matter. Just aim it and go. With the FEL it doesn't even feel light in the front. I got the synchro shuttle transmission which works well for my purpose. Especially like the tilt steering and the reclining seat with armrests. It is spacious and comfy. Very pleased with this purchase.
/ New Kubota M5140 owner #31
/ New Kubota M5140 owner #32
Very nice tractor, looks like it's ready to eat up some brush. Beautiful view also.
/ New Kubota M5140 owner #33
Here she is on top of one of my hills after I just finished bushogging. I have never seen this hill completely cleared of blackberry bushes and small trees before. I'm loving this thing.
I read the tacked threads about rollovers. Watching those videos is sobering but a good thing to see. I wont be mowing side to side on hills anytime soon.
Hi I just bought a M5140 new to me with 660 hrs on it. What make and model rotary mower do you have, As I am looking to get one. Thanks
/ New Kubota M5140 owner #34
ON a 2nd look I opened picture I see it is a Woods BB72
2007 BOBCAT S250 SKID STEER (A60429)
2007 BOBCAT S250...
2016 John Deer 5075E (A60462)
2016 John Deer...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2008 Jeep Wrangler Unlimited 4X4 SUV (A59231)
2008 Jeep Wrangler...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
