New Kubota 3901 PTO running in both the engaged and disengaged setting
   / New Kubota 3901 PTO running in both the engaged and disengaged setting #1
CindyCRNA
Near Kansas City Kansas
L3901 HST
I was mowing today and went to get off to move something and the tractor shut down. I thought I had neglected to disengage the PTO and had tripped the seat shut off. A quick google search did not help so I called my dealer. He said while pushing the PTO lever to the disengaged setting firmly and I got it restarted but the PTO continued to run in both the engaged and disengage setting. So I didn't get off the tractor for 5 hours! I am assuming this will be a service call. What is the fix? I have owned it a year and it has 45 hours on it.
   / New Kubota 3901 PTO running in both the engaged and disengaged setting #2
Do you hit the clutch when you disengage the PTO? I'll flip mine off but unless the RPM's are changed or I hit the clutch, the PTO will still stay "On"...
   / New Kubota 3901 PTO running in both the engaged and disengaged setting #3
My local Kubota mechanic strongly recommends depressing the clutch before disengaging the PTO to prevent undue wear of the gears.
   / New Kubota 3901 PTO running in both the engaged and disengaged setting #4
Is it really “engaged” or is it just “spinning”. That is, if something was connected to it, is there any real torque?
Though, I guess if it’s engaged enough that the safety switch is still activated, it’s probably really engaged.
   / New Kubota 3901 PTO running in both the engaged and disengaged setting #5
Not sure how yours works. On the L3200 I had there was a sticking cable / gadget under the tractor that was fixed really fast with some lube.
   / New Kubota 3901 PTO running in both the engaged and disengaged setting #6
Was just going to make the same point. The PTO cable mechanism is not something that gets "reinvented" every time a new model comes out. It's pretty foolproof IF it remains lubricated so dust, grass clippings, etc., doesn't bind it up. I always gave mine a shot of spray lube every few months.
Oh no, I mowed for 5 hours with it disengaged.
I called the dealer today and they said the same thing. I just got done mowing 4 1/2 acres of weeds that were 8' tall and loaded with pollen so t\I bet thats what it is.
So how does one clean this cable? Do I just follow it to the transmission and clean and lube it? Is it obvious once I get under there?
   / New Kubota 3901 PTO running in both the engaged and disengaged setting #10
Hst you have to remove the cover under the seat... a few photos... You pull the rubber boot back and fill it up with lube on both ends... I would also lube the spring, too...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Landoll Hauloll (A52748)
Landoll Hauloll...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
