New Kioti CK3510SE Owner
   / New Kioti CK3510SE Owner
New tractor (y) if your going to call the dealership do walk around list anything else needs attention.
Thank you Thomas that is good counsel. I will do that as well.
   / New Kioti CK3510SE Owner #12
Thank you so much. That's very helpful. Will call the dealer Monday morning.
Yes, let your dealer take care of it . . . your tractor is a warranty baby :) and have the dealer while he is at it to check other things that the dealer does when they receive the machine.
   / New Kioti CK3510SE Owner #13
Ya beat me to it Thomas . . .
   / New Kioti CK3510SE Owner #14
I agree with the others, let the dealer take care of it. I took the dash apart on my CK3510SE to add a left hand brake pedal. I needed the service manual to figure out how to remove the covers. Here is a picture of the steering valve. It is in a tight space.
Thanks again to all for this good advice. I took it to my dealer and combined it with my 50 hour service. They could not find a leak, but concluded the factory applied grease around the steering column had heated up with use and started dripping. They cleaned it up and it will be returned tomorrow. Relieved with that result and grateful for everyone's helpful advice. Glad you are all there.
   / New Kioti CK3510SE Owner #16
That sounds simple. Keep an eye on it, and make sure that's all that it is.
Thank you for the update. 👍
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
