New King Kutter or Used MX5 ?
   / New King Kutter or Used MX5 ? #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
OK....already I have a dilemma.....:confused:
I can purchase
1. a new King Kutter 60" HD with slip clutch for $1629.
2. a new lighter duty 60" King Kutter for $759.
3. a lightly used (looks very nice top and bottom) MX5 with slip clutch for $1300 with a new set of blades. (The original blades are fair to middling.)
Any of these cutter choices would go on a JD 790. I am leaning toward the MX5.....but.....Opinions?
   / New King Kutter or Used MX5 ? #2
I would go with the MX5 IF your 790 can lift it...check the weight as the MX's are built like a tank! JD would probably recommend the LX5 for this reason.
Thanks Kenny.....that was the direction I was heading too (the MX 5) but I wonder too about the weight on the back. I looked it up and it weighs about 865 lbs. :eek: Seems like alot for this little tractor....and that has me concerned too. Anyone have this combination (790 with MX5) ?
   / New King Kutter or Used MX5 ? #4
I have an MX5 on the back of my 3720. Its great! and heavy!!! Our 4110 can lift it. but needs a bucket full of dirt to be stable.
   / New King Kutter or Used MX5 ? #5
That's alot of iron for a 790! (Pretty good price, though.) If you weren't planning on using the mower in hilly terrain or in heavy, tall weeds, etc. -- you've likely got enough pto horses to manage the thing.
But, if you've got slopes and sidehills, etc. - get the light duty KK.
Best of luck.
AKfish
yep.....alas....I think the MX5 is a bit too much weight :eek: for the 790 to handle in rough country. I think I will keep looking for a little while....the light King Kutter is always available......and likely a good choice for me. :)
   / New King Kutter or Used MX5 ? #7
This is an easy one, MX5!
   / New King Kutter or Used MX5 ? #10
i've always opted for used quality equipment over new lesser made equipment......
2014 MOROOKA MST 3000 VD TRACK DUMPER (A52705)
2014 MOROOKA MST...
Landoll Lowboy Trailer (A55218)
Landoll Lowboy...
2013 UTILITY DRY VAN TRAILER (A54607)
2013 UTILITY DRY...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
