New Kama TS354C 4x4 problem
   / New Kama TS354C 4x4 problem #1
RayHad
Just got a new Kama TS354C with 7 hrs. on it. First time I put it in 4 wheel drive there is a knocking noise coming from underneath. Any help would be appreciated.
Thanks,Ray
   / New Kama TS354C 4x4 problem #2
Be sure the lever is fully engaged. when going into 4wd you need to be slightly moving as you engage the lever to allow the teeth to line up and fully engage. also sometimes you will have to back up slightly to disengage. Never operate in 4wd on hard surfaces.
Thanks for the help. I tried engaging while moving,it did'nt
work. When engaged it makes knocking noise in forward, reverse and nuetral while moving.
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
5K BLOWOUT PREVENTER (A50854)
5K BLOWOUT...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
