</font><font color="blue" class="small">( I gave him $1200 for the tractor and the blade. It is a hydrostat, and like I said, in near perfect cosmetic condition. No smoke, no rattles, no bad vibrations. I would just hate to think that I got bent over on the deal. )</font>
KyleLevi,
First, welcome to TBN.
I've got a 180 w/ 46" mower. Purchased in early '86. It is an awesome tractor. The Kawasaki motor is one of the best air-cooled engines ever. The engine is a bulletproof tank. I have well over 2000 hours on mine. (I put an hour meter on it, and it died in the late '90's with 2300 something on the clock.) I felt guilty about 10 years ago and replaced the spark plug! It still starts and runs perfect.
Now, what sucks on the tractor.
Do NOT leave the ignition key in the switch. It corrodes the terminals inside, namely the purple lead that engages the starter solenoid. I'm on about my 7th switch. At $15.00 or so a pop, I've been jumping from the battery to the solenoid terminal at the starter (sorry, It's not the perfect tractor, and I'm cheap). I had a JD battery boil over and ruin a fuse holder and PTO switch. I'm on my 5th battery now, this battery has been really good. I've already had to rebuild the transaxle. Also, had to repaint the fender. The paint would lift off in large flakes.
That's it.
Change your oil and maintenance the air filter regularly. Keep the mower deck clean, top & bottom. Don't be lazy, remove the belt shields to clean under them. If you use water, make sure you air dry it well. Otherwise, it will rust in no time flat. Once it starts rusting around the bolts that hold the bearing casings of the blade spindles, it's too late (the blade torque will finish it off quickly). Also likes to rust where the rear lateral links fall on the deck. This is an ongoing fight to keep the rust off here. And yes, it will cost over $1,000 to replace the deck and rebuild it like new. Also, don't let the blade bolts stay too long, the hex will get completely rounded over time and then they are a bear to remove.
Now, for some good news.
Oil Filters:
John Deere oil filter - expensive - #AM107423
Wix oil filter - 51394 - much better. Fram oil filter - PH4967 - better still (It's a common Toyota filter). About 1/3 the price of OEM. Purolator oil filter - L414476 unknown?
Air Filters:
Much less choice here.
John Deere Air filter - expensive - #M97266 Paper filter.
John Deere Air filter - expensive for what it is - M70127 Foam Pre Filter - Never have found an aftermarket for this. /forums/images/graemlins/frown.gif
Wix Air Filter - 42439
Fram Air Filter - CA8593
Fuel Filter
John Deere Fuel Filter - AM107314 - Never have found an aftermarket for this either.
If you can, always use NGK spark plugs.
NGK #BPR5ES .025gap.
I guess that's all the advise I can give you. Oh, yeah, be sure to register at
<font color="green">John Deere</font> so you can take advantage of the parts lists, etc.
Have fun with your new tractor.
