New JD 4100 owner....what engine oil to use?
   / New JD 4100 owner....what engine oil to use? #1
iqraceworks
Missouri
John Deere 4100
I just inherited a JD 4100 tractor. I want to give it a good starting point by changing all of the fluids and filters. I've already ordered the JD filter pack kit with the air, oil, fuel, and hydraulic filters.....but I'm wondering what type of engine oil should use. Should I stick with the JD brand oil and weight that is specified in the manual, or will the Rotella 15w-40 that I use in everything else be a good oil for my "new to me" 4100?
Thanks!
   / New JD 4100 owner....what engine oil to use? #2
I just inherited a JD 4100 tractor. I want to give it a good starting point by changing all of the fluids and filters. I've already ordered the JD filter pack kit with the air, oil, fuel, and hydraulic filters.....but I'm wondering what type of engine oil should use. Should I stick with the JD brand oil and weight that is specified in the manual, or will the Rotella 15w-40 that I use in everything else be a good oil for my "new to me" 4100? Thanks!
I have used Rotella 15-40 in my John Deere tractors for years and have had no problems. It's an excellent oil.
   / New JD 4100 owner....what engine oil to use? #3
Rotella in my Kubota, and in the John Deere.
In fact I use it in my Motor Cycle too.
   / New JD 4100 owner....what engine oil to use? #4
Be better in the winter with the Rotella 5w40. Actually, it'll reduce wear to overhead valve area all year round by getting the oil up there quicker. Most wear occurs on startup, and that's when the (low)wxx oil helps a lot. It's what I used in my 4010 and 1025. Probably will use it in the 2025 if not the Mobil 1.
I found a Mobil 1 5w40 for diesels, too. Plan to use it in my generator when it ever gets to 50 hours.
Ralph
   / New JD 4100 owner....what engine oil to use? #5
C'Mon, man. Don't leave us hanging in the other thread.:) You should update us over there and let us know you got the tractor. It's fun when someone gets a new machine. Especially when it'sit'sit'sit's handed down through the family.
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
Hose Reel (A55787)
Hose Reel (A55787)
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
