new injecters?please read story
   / new injecters?please read story #1
jerrywane
Eastern K.Y
cub cadet #8354
Cub cadet 8345,3 cyl.40 hp,985 hrs......driving along and all of a sudden it seemed the throttle cable snaped.Look into it and it was fine.R.P.Ms will only go to1700 when top is 2700.rpm.Now this is confusing me i rea lized that the spring that pushes the fuel filter up is gone,and has been for a whileBasically the filter wasnt filtering because of the missing spring .....NOW,i pulled the injecters and cleaned them,brought em to our local tracter repair shop,where he hooked them each up to a pressure tester and the things were shooting streams instead of mist.Now this is confusing me because it purrs like a fat cat,and idles just as nice.I ordered the injecters x 3 and the spring for the filter housing.....it just doesnt seem right that all of the injecters went the same way with no warning/and there is no excessive smokeing @ the exhaust.I am going to compare them side by side when they come in to the old ones,i just find this a lil hard to believe....any thoughts???:confused2:
   / new injecters?please read story #2
The IP is probably damaged internally too. something is causing it to not go to full fuel but run fine all other times
   / new injecters?please read story #3
If you are lucky the injectors are the only thing that is bad, The debris that pluged the injectors also passed through the injector pump. You may be replacing it too. The spring for the filter would have been a lot cheaper.
Bill
   / new injecters?please read story #4
Are you sure that your fuel delivery to the pump is unrestricted? You could have some crud in the tank clogging the outlet and that will limit the rpm just as surely as a clogged, iced up, or jelled fuel filter.
Are you sure that when they pressure tested the injectors that they were at the correct pressure? If the tractor otherwise ran well, it doesn't seem likely that all the injectors were the problem.
   / new injecters?please read story #5
I am not familiar with the injection pump set-up in that machine. The all of a sudden nature of your problem makes me wonder if it is a governor problem. Like a broken governor spring. I also wonder about the injector testing method. I have my own tester and I can make an injector spray a stream instead of a cone pattern by how I pump the handle on the tester and what pressure I allow it to reach.
As was suggested I would start at the tank and work my way forward to make sure I am getting a steady flow of fuel at each point in the system.
Brian
i took IT APART SOME MORE,AND SURE NUFF IT WAS A BROKEN RETURN SPRING ON THE GOVENER awesome help ! persistance pays off......waiting on the $1.53 spring.....i believe!!!!!!!!but well see. thanx man,if this is it , you gotta free dinner on me if you happen to be around:thumbsup: this link is too the page diagram link......replacing# 18,19,20 Parts and Diagrams for Cub Cadet 8354 Tractor
   / new injecters?please read story #7
Yep, that is the same style Kubota's use, that I am most familiar with. I'm glad you found it.
Brian
   / new injecters?please read story #8
G'day glad you found the fault i think the shop that tested your inj where looking for a free meal i think i would be staying away from there in the future
Jon
I hope this to be it.I coild have broked the sprping taking it apart......this will be a test....it is only a test.If this had beeen an accual emergency,youd probably e dead right now! Will update the progress
Put the new $1.53 cent spring in put her back together and she runs like a scallded dog........thank alot guys.Some one had mentioned the spring and reps on there way.And no i dont think the guy(hope is more like it} was trying to sell me injecters,its:thumbsup: just that his mechanic was out sick,and i dont believe he would do this to me.He just didnt run the right pressue thru them.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2004 KENWORTH BUCKET TRUCK (A50854)
2004 KENWORTH...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
