New HST Stupid Question
   / New HST Stupid Question #1
Steppenwolfe
Super Member
The Blue Ridge Mountains
Kubota MX5400, 1140 RTV
Hey Guys, I have a stupid question. I just bought a Kubota B2320 HST for our 5 acres and cabin in the mountains.
I have never used an hst tractor before and would like to know if there are any secrets, tricks, etc to learn. It sure is small compared to my other tractors, both gear drive, but I wanted small for the manuverablity. I took it out today for an hour and played with it, and it sure is different than what I am used to. But, I kinda like it... Any imput will be appreciated. Thanks
   / New HST Stupid Question #2
The go pedal is not an accelerator. It is more a seamless "gearshift". Pushing it a little gives you a low gear. Pushing it a lot a higher gear. ... Your ranges are true gear changes, allowing greater force to be applied with the seamless gearshift, but lowering your max travel speed.
The root is that your go pedal varies the displacement of the hyd pump that supplies fluid to the hyd motor that drives the actual gears powering the wheels. There is a PRV between the pump and motor. Max torque from the motor is thus limited by the PRV. But if you go down in your true gear range the multiplication of motor torque afforded by the gearing lets you seamlessly push harder but at reduced top speed.
The go pedal is not an accelerator. It is more a seamless "gearshift". Pushing it a little gives you a low gear. Pushing it a lot a higher gear. ... Your ranges are true gear changes.
Ahhh... That's good to know. Less push, more power? and more push, less power more speed???
   / New HST Stupid Question #4
I did some editing while you were replying. Pls take a look and see if you have the same question.
   / New HST Stupid Question #5
In other words, yes. Exactly.
If you understand that concept and are willing to set the throttle up a little ways and go play around, you will find the HST incredibly simple and intuitive use.
I honest to God have no idea what you just said. I'm basically a Carpenter, not an industrial mechanic. So...push easy and steady, don't floor the go pedal like a foot throttle. :newhere:
   / New HST Stupid Question #7
Yes the go pedal is a trade off between speed and power. You need to learn to use a combination of the pedal, range selector and throttle to get what you want.
   / New HST Stupid Question #8
Too bad.... But yes. If you can ask a question I will help.
Now that I understand. My RTV is basically like that, but feels a lot different.
I think I will. Are there instances where it would make sense, for the sake of the tractor, to run M with little pedal push vs L with more pedal push? Am I making sense?
2003 Freightliner FLD 120 Columbia (A56435)
2003 Freightliner...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2007 Capacity TJ6500T Trailer Jockey Truck (A55973)
2007 Capacity...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
