New House Build in the Country!!!
   / New House Build in the Country!!!
I ran 12/2 romex 800 feet to my front gate with a 20 amp breaker to power a pair of lights at either side of my gate. At first I put in some regular candlabra light bulbs, but they didn't last very long. I switched them out and put in LED light bulbs instead. They have been in there for about ten years now without a problem.
I know that I lose voltage and amps over that long of a run, but I figured it was acceptable for what I wanted to do. I could have spent more money on larger wire and had less loss, but since I don't need any more power out there, I feel it was an acceptable decision.
Eddie,
You convinced me. I went ahead and bought enough wire to do two runs of 12/2. It should work well for road lighting. The wire was pricey!!! It's been an expensive day .
   / New House Build in the Country!!! #82
Eddie,
You need to throw something in there to get your camera image back. Don't know what that would be, wish I would have done it. Did the power.
   / New House Build in the Country!!! #83
At that distance (if its a network camera) it would need to be fiber or something like one of those DSL network extenders.
Aaron Z
Question for everyone.... On Friday they came and trenched in the water line to the house. They did a good job, but i'm concerned about where they crossed the creek. On Friday the pipe was covered, but today you can now see the pipe on the surface of the water. I figured that they had not gone deep enough originally, but I didn't realize just how shallow it actually was. What do y'all think the best option is? They could do a 90 degree on each side of the creek and get the pipe deeper that way. Are there any other/better options?
Thanks!
   / New House Build in the Country!!! #85
Don't know, but can you add dirt above the pipe or a small reroute in the creek ? Keep it well marked for future concerns also. Good luck.
   / New House Build in the Country!!! #86
Looking at your secondary garage, I note that you show 9' (width?) doors. While it probably varies by manufacturer, my 10' door only has a throat width of 9'-10".
My Ford 150 with mirrors in the inner position is 8'-9 1/2"" and when extended to the towing position it is 9'-4".
A 9' door may only have a 8'-10" throat. Gonna be tight to get a pickup in there.
My cost of a 10' over 9' door (insulated with interior metal panels) was less than $100.
   / New House Build in the Country!!! #87
Thanks!
Who is "they?" Was it a plumber or the utility company?
When crossing a creek, my water utility company has some requirements. I forget how deep you have to go, I'm thinking 2 feet, but the water pipe has to be encased in a steel pipe and then the trench has to be filled with concrete.
This is unacceptable and will lead to failure.
It was put in by the same guys who are doing the grading/driveway work. Should I ask them to dig it down two feet and case it in another pipe? I'm not sure that I want that pipe cased in concrete.
I agree that the current placement is not acceptable.
   / New House Build in the Country!!! #90
All soil moves. Some soil moves more then other soil. Pipes in the ground break because they cannot handle all the movement of the soil.
Putting the water line inside another pipe allows the water line pipe to move, which reduces that chance of failure. Pouring concrete onto the water line would increase it's likelihood of failure because the concrete will move with the soil and stress the pipe.
If for some reason the water line ever failed, you could replace it because it is inside another pipe.
The only other option that might work is to bury the pipe at the bottom of the ditch going through the creek with a layer of sand, then pouring the concrete on top of the sand. I know that some cities do something similar to this.
When burying a line under a creek, the few times I've seen it done, they dig the trench and use the dirt to dam up the creek. You can only do this when it's flowing slowly, or not at all. Then after the trench is dug, they lay the pipe with the sleeve in the trench and then back up the cement truck and dump a couple of yards of concrete into the trench. I have never seen them take down the temporary dam. I was told it will wash away on it's own and it's better to let the concrete set without the water over it as long as possible.
This is here in my area of Texas.
I would either try to look up what code is there, or go talk to somebody at the Water Utility to see how they do it. I would consider what the Water Utility does to be gospel and I would do it exactly how they say to do it. I would not pay your plumber until it's done correctly. He might charge you more, but whatever it takes, I would not leave it like that.
PIONEER PUMP 4 TRANSFER PUMP (A55745)
PIONEER PUMP 4...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55302)
Mahindra 4550-4L...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
