New Holland Workmaster 75 is emitting blue smoke only when going downhill
   / New Holland Workmaster 75 is emitting blue smoke only when going downhill #1
Ron Cloninger
Central Illinois
New Holland Workmaster 75, Jinma 354
While mowing yesterday I noticed that every time I go downhill, the tractor will emit blue smoke and at the end of the day the engine oil level was a little low, but not below the minimum oil level. Any ideas? This tractor does have a turbocharger.
   / New Holland Workmaster 75 is emitting blue smoke only when going downhill #2
Check the pipe connecting the tube to the intake manifold if there is any oil residue, do not run the tractor except to move it to a suitable repair location. You are risking a runaway engine and the associated catastrophic engine failure.
Thanks. If you mean the hose from the turbo to the intake manifold, there is nothing showing. This only smokes when going downhill. I was mowing and running around 2000 rpms. Probably used a pint in 6+ hours. The only downhill part is a mystery to me
   / New Holland Workmaster 75 is emitting blue smoke only when going downhill #4
Nothing showing on the outside, or inside of the hose?
Maybe very very soon slight on the inside of the hose. Cleaned with paper towel and only seen black from the hose. What do you think about only while going downhill? Thanks for your replies
   / New Holland Workmaster 75 is emitting blue smoke only when going downhill #6
Low boost pressure under light load. Check your air filter and intake plumbing for restriction.
I will check that tomorrow, I have not checked the air filter lately. Thanks for your help.
American LaFrance Thermoplastic Striping Truck (A52377)
American LaFrance...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2022 CATERPILLAR 317 EXCAVATOR (A51246)
2022 CATERPILLAR...
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
