CajunRider
Platinum Member
Here is my situation:
Equipment I own: 6ft rotary cutter, 6 ft box blade, a broken 6ft flail mower that I just might repair some day, a Kioti DK45 with FEL that has been flooded in two hurricanes, a Kubota T2080 riding mower to cut grass immediately around my house.
Land: 7 acre homestead half dry half kinda wet with standing water (about 4") 3 months/year.
The house pad is built up high with slope steep enough for me to feel concern at times but is generally not too bad.
1200 ft long drive way built up 18" higher than my land. The slope along the drive way is pretty steep but I've been able to deal with it with my DK45.
Things I have to do: * Cut grass on my land once a month. The grass on the wet area is the tough wire grass.
* Twice a year I cut around the perimeter of a 10 acre pond that belongs to my neighbor. Usually when I cut the brushes and canes have grown to be about 5-6 ft tall.
* Maintain the area around 1 acre pond and the lake bank area around my house. The land is soft & boggy with brushes and canes growing there.
* Grade & maintain 1200 ft gravel driveway.
I need to replace my DK45 because keeping it takes way too much of my time. With so much salt water on it in the past, it's a rust bucket that keeps falling apart.
Based on past experience of trying to get tractor service in my small town, I've pretty much narrowed my choice to one dealer that is reliable and reasonable. The dealer carries New Holland, Kubota, and Mahindra.
With my ailing knee, I would very much want a tractor with HST so I don't have to work the clutch. Due to budget constraint, I'd like to keep my cost as low as I can but buying new tractor. I've given up on buying used tractor.
What I need advice on: 1)Recommended tractor models of New Holland, Kubota, Mahindra for my stated needs. I don't want to rely on the dealer input because the dealer has inherent bias and can't be independent in my opinion. If you have experience in a model of any of those three makes, please chime in.
2)Pros and cons of the 3 makes mentioned above.
3)Should I sell my implements and down size to a smaller tractor?
Thank you for all your help.
