New Holland TS90 1998 tachometer problem
   / New Holland TS90 1998 tachometer problem #1
JiiN
Finland
New Holland TS90
I have problems in my TS90 1998 with tachometer. It works properly in cold but when cabin heat rises up, it often stop working and jam to 0rpm or 700rpm etc. Alternator and tachometer is changed to new one and problem didn't solve with that. I've cleaned alternator's W connector about thousand times. Do You guys have a good hints where and what i should do next to solve this problem?
   / New Holland TS90 1998 tachometer problem #2
Bad soldering at the circuit board?
Do You mean gauge's circuit board? Tractor had same problem with old tachometer so I changed it to new one.
   / New Holland TS90 1998 tachometer problem #4
I had a similar problem on a boat years ago. What I put it down as was. The taco W lead as you say, sometimes T, is taken off one of the usually three coils within the alternators AC windings. When you start, the battery will be slightly low, the small wire going to the alternator will tell the voltage regulator to produce current so the inner coils work hard producing a strong AC pulse. As the battery comes up to full voltage, the alternator decreases output, and the AC pulse from the main wiring drops to almost zero, thus giving a week signal to the taco and false readings. This might not sound very scientific, but it seems what happened to my boat. My answer, I bought one of those cheapo Chinese tacos off ebay and epoxy glued a small magnet to the front crank for the sensor. It worked well for years and was still on when I sold the boat. I suppose to test this theory, the next time the taco gives false readings, try switching the lights on full to make the alternator work harder.
   / New Holland TS90 1998 tachometer problem #5
There are three elements, alternator, tach and wiring harness. You have changed 2. Check the wiring, including the instrument cluster ground and the cab bulkhead connection.
That's what i figure too. Does anyone know a color of a wire which gives a signal to tachometer?
I've noticed earlier that it doesn't matter is the all lights, heater and radio on. It just stop working when cabin gets warmer, like really hot summer day tacho isn't working almost at all.
And i almost forget to say.. PTO works fine when tacho is having issues to work.
   / New Holland TS90 1998 tachometer problem #9
That’s narrows a probable wiring issue to the cluster ground path and the tach signal circuit from thetach to wherever the tach signal is split to feed the tach and the safety circuit.
Does anyone have a wiring diagram? It would be lot easier find the right wire.
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
