new holland ts125a charging system problems
   / new holland ts125a charging system problems #1
groomerman
houghton,michigan
ts125a
battery has been load tested and is good, was testing as low alternator voltage. put in a reman alternator and still running off battery. cleaned terminals on battery and where connected to alt. also where it runs to the starter, tried wiggling connections to see if would change charging voltage but no luck. there is reallu only the positive (MAIN) feed , a groung to the alt. case then 2 small wires both connected to the middle terminal. any help would be great as we still have a lot of snow and the tourist like smooth grommed trails up here in the Copper Country.
   / new holland ts125a charging system problems #2
Hi. Welcome.
If alt is putting out then it is not getting to the battery. You have check the positive and some ground wires. Check the main ground wire by removing the connection at the frame and clean and retighten.
There are several ground wires but the neg. cable on the battery goes straight to the frame. The next potential problem could be the voltage regulator is not functioning.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
