New Holland TS 110 PTO
   / New Holland TS 110 PTO #1
rooster1980
central texas
john deere 5085M, john deere 1025R, Massey Ferguson 2607H, Ford 3600, Allis Chalmers G new holland TS110
The pto shaft is interchangeble, is there some way i can add a spacer and get the 540 pto rpm at 1100 engine rpm. I know some tractors have the switchable pto speed lever which makes this possible,
   / New Holland TS 110 PTO #2
Normally the pto speed is determined by a set of fixed ratio gears. You can only get 540 rpm at one speed or a 1000 rpm at another. I don't know how a spacer would work to change that.
   / New Holland TS 110 PTO #3
I can't say for sure but I'm thinking the gear for the 1000 rpm was further inside the case then the 540 gear.
The easiest would be to install the 1000 rpm shaft and use a 21 spline to 6 spline adapter.
I know some older tractors when you flip the shaft the 540 side is longer and pushes against something inside that changes the speed to 1000 rpm. I don’t know if the ts 110 is the same way or not.
   / New Holland TS 110 PTO #5
Could be, none of the older Fords and New Hollands that I'm used to change the speed they all picked up a different gear in the PTO housing.
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2019 FREIGHTLINER CASCADIA (A52577)
2019 FREIGHTLINER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
