New Holland tractor TC 34DA
   / New Holland tractor TC 34DA #1
tmac2
Tc 34 DA Hydo 4 wheel drive -240 loader and woods BH 70 X Hoe R-4's
$23225.00 ?
are these hoes good ? how are the New Holland Tractors currently own JD
First new tractor purchase for me not sure what to expect from dealer - Setup- delivery etc
what lift capacity number is one that realisticly represents the loader lift capacity? these loader manufacturers all use different types of measurments
I have a small horse farm will use the loader to move hay, manure, gravel , condition riding area, as well as gravel road maintanance, some brush hoging, drainage systems stump remval etc
your advise will be greatly appreciated
   / New Holland tractor TC 34DA #2
I like the Woods hoes, but make sure you get a subframe--that would apply for any hoe you put on that tractor. Without a subframe, you risk (in time) having your tractor snap in half--literally.
For the loader, I'd go with the number 20" or so forward of the pivot pins. That's the most realistic figure for what you can pick up.
Set-up and delivery would be dealer dependant.
   / New Holland tractor TC 34DA #3
I've got a DX33 that I'm getting ready to trade in for a DX45. It has the LX14 loader which should be similar to yours on the 34DA. The lift capacity will vary depending on the load placement. My 33 will lift a 1,000# evenly stacked pallet using pallet forks off of a trailer, but will probably not lift it past shoulder height. Using the bucket which brings the weight in closer to the tractor it will probably lift 1,000# to full height or close too it. I think ODT is right using the 19.7" specs. This list out at 875#'s. Good luck with the 34. My 33 is a great tractor and has outperformed my expectations. Just looking for something bigger and a cab.
**for the task you've mentioned, you might look at the next size up - TC35/40/45 if it fits your budget. While the 34 will handle it, you may find yourself in my situation shortly, wishing you would have went a bit bigger, especially if your not finish mowing around a lot of trees and tight areas.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2018 JLG 3246ES 32FT. Scissor Lift (A51691)
2018 JLG 3246ES...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2008 INTERNATIONAL MA025 REEFER BOX TRUCK (A52577)
2008 INTERNATIONAL...
