New Holland TN75D Clutch /Pressure plate issues.
   / New Holland TN75D Clutch /Pressure plate issues. #1
spedracr89
TN75D
Looking for ideas on what would cause the main clutch arms to break the fingers off the pressure plate after 1 year of install. Also how or why would there be water in the back and bottom of the bell housing area of the transmission? Trying to figure out what is wrong or needs corrected before replacing the whole clutch assambly.
   / New Holland TN75D Clutch /Pressure plate issues. #2
Does the tractor sit outside in the rain is my first question. Clutch fingers usually fail from not enough free play prior to engagement. If it sits outside in the weather you need to modify the drain plug so it will evacuate water as it collects.
Yes the tractor sits outside 24/7. "Clutch fingers usually fail from not enough free play prior to engagement" So you are talking clutch pedal height adjustment since it is the main clutch fingers?
   / New Holland TN75D Clutch /Pressure plate issues. #4
In the rain I take it? Where your water issue is coming from, especially if the gear shift or range shift boots are compromised. Had that happen on one of my open station M's a couple years back. I replaced the boots with new ones but then my units stay inside. Compromised boots also allow dirt to get in the gearbox as well. In reality no tractor is water tight.
   / New Holland TN75D Clutch /Pressure plate issues. #5
The specification on my Kubota's is 1/2" of free play at the clutch pedal and if it sits outside all the time you need to block the clutch pedal down so the clutch is actuated when not in use. Manual clutches have a bad habit of freezing to the pressure plate if left sitting not engaged (clutch released) for a period of time.
Well it is an enclosed cab however one of the doors has a broken glass so both doors have been removed. So it is possable for rain to get into the cab area. Will check the shift boots for damage. Will look for the drain plug and see about modifying it.
   / New Holland TN75D Clutch /Pressure plate issues. #7
If it has a drain plug in the bellhousing, remove it and drill a suitable sized hole to accept a short length of steel drill rod, peen the one end over and drop it in the hole so it sits inside the bell housing.. That way any moisture that collects in the bell housing can escape when the tractor moves and the rod wiggles in the drilled hole. That is how Kubota addresses the issue and it works very well.
So follow-up, think the bearing that rides againts the pressure plate fingers was installed wrong. The groove side was installed towards the transmission instead of the pressure plate. Being told that the groove side should be towards the pressure plate. Is that correct?
   / New Holland TN75D Clutch /Pressure plate issues. #9
I've replaced a number of clutches in TN series tractors, along with the respective release bearings. Depending on the supplier, the main clutch release bearing may or may not come with a new contact sleeve already installed that rides against the pressure plate levers. Those supplied by New Holland do, as so do some from other suppliers. I am not aware that a new replacement bearing could be installed backwards. Of all the tractors I've done I have yet to hear of any that failed due to my having made that mistake.
Where does your information come from regarding this fact?
So to clarift I am not a tractor expert and more than likely will call some things by the wrong name. I took some pictures and will attach as many I as can to help clarify what I am saying.
Few questions/answers.
1. "new contact sleeve" How can I tell if the current one has the new conatct sleeve?
2. "new replacement bearing could be installed backwards" After looking at the part again it was not the bearing but the housing that the bearing is installed. It is the smaller of the two bearing holders.
3. "Where does your information come from regarding this fact?" Someone who stopped by and was able to look at the parts. Then I was told by someone else what was said. So I might have been told wrong or misunderstood. That is why I am asking here.
So here are 5 pics. Have high res versions available if needed.
1. Is the bearing_installed_order pic correct or is one or both backwards?
2. The back_side_pressure_plate showing the broken ears on the pressure plate.
3. Does the wear spots on the shaft in Needs_replaced_or_still_ok_to_use picture show enough wear to cause issues and needs the shaft replaced?
4. The "This_side_to_pressure_plate_ears_1" picture is the one I was refering too in the "The groove side was installed towards the transmission" statement above.
2012 Mack CXU613 Sleeper Truck, VIN # 1M1AW07Y3CM018973 (A51572)
2012 Mack CXU613...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
HLA SE50AO600G LOT NUMBER 168 (A53084)
HLA SE50AO600G LOT...
