New Holland TN70a Hydraulic Help?
   / New Holland TN70a Hydraulic Help? #1
LCH78
San Antonio
New Holland TN70A
I am new to TBN and posted this in the hydraulic forum. I didn't see the New Holland forums so I am posting my situation over here. I have learned quite a bit on these forums, but am trying to find any advice regarding the follwoing.
I should let all know that I am not a mechanic, but have been able to handle most repairs on this and my other equipment for the last 25 years. I am hoping someone can give me some advice on the hydraulic system on this tractor.. I have a New Holland TN70A tractor with a NH 32 LC loader attached. I have recently started having problems with hydraulic leaks at the Mid Mount Float Valve bucket controller.
Additional info that might be important: I "lent" my tractor to a neighbor for an extended time and I know that it at least one hose (maybe more). I notice that when making a left turn, the hoses hit on the right tire. I am now thinking that the replacement hoses were made too long. I guess it is possible, that with the way the hoses hit on the tires, that the couplers are "taking a beating" so to speak. Does this sound plausible? Or would some of you with more experienced in hydraulic systems suspect other items to check?
I have considered replacing all couplers and hoses with I know are the proper length. They are mounted under the driver's platform.
I am attaching a picture of the valve. Only one of the four hoses are attached in the picture, but leaks had developed on the two lines on the right side of the valve. I replaced the seal on the upper right coupler and replace the coupler and seal on the lower right coupler (absent in this picture). Everything was fine for about four months, when the same two valves developed leaks again. I replaced the seals (the seals where the valves contact the valve block) again, and within 6 hours of run time both seals were leaking badly again.
The system seems to be getting much warmer than it used to, and I should mention that the remote stack on the rear of the tractor has also recently developed a leak. I have two sets of remotes. The leak appears to be coming from in between the two remote "blocks".
Anyone know where I might find a copy of a shop manual for the TN70A without breaking my budget?
Thanks for taking time to read this post. Any advice would be appreciated.-jp MIDMOUNT.jpgMIDMOUNT.jpg1445219761957.jpggNew Holland 32LC Loader Valve Help Please-midmount-jpg
   / New Holland TN70a Hydraulic Help? #2
Posted yesterday and no responses.
I guess I will reply though I do not think I will be much help.
First of all. You loaned your tractor to your neighbor. You must really love your neighbor.
Proper length hoses are a very good thing to have. You say the long hose hits the tire and causes the couplers to take a beating. Are the hoses being pulled on by the tires? If so that must be fixed. No hose should be pulled tight or bent hard.
As far as the couplers leaking I would suggest you clean up and dry all the fluid and dirt in that area, and keep a close eye on it to see exactly where the leak is coming from. If a coupler is leaking I like to replace it, instead of repairing it.
28013 (A50322)
28013 (A50322)
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
RIGID TOOLBOX (A52472)
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
Adams 8 Ton Weigh Hopper (A52748)
Adams 8 Ton Weigh...
