New Holland TN65S error/fault code problems
   / New Holland TN65S error/fault code problems #1
JohnM575
New Holland TN65S
Hi there,
I am asking a question on behalf of my father. We have had a few error codes problems in which we have solved , but are stuck on error code 14 for a TN65s.
I understand the manuals will have a full list of the codes, but is there a link someone may be able to shoot my way to view a full list?
Thanks in advance.
   / New Holland TN65S error/fault code problems #2
Hi there,
Thanks in advance.
No. If you want the full list, you have to pony up unless someone will send you a pirated document. The manual also has detailed troubleshooting. If you don't want to buy the complete manual set, buy the transmission section. That has what you need.
Choose Items
Fault 14 is gear shift switch signal voltage shorted to 5V or 12V. That's the gear shifter, not the range shifter.
Cheers for the quick reply Rick.
I will let you know how we get on, our mechanic was wondering the code error as we just purchased the tractor and do not have any manuals for it at this stage.
Lets hope its a quick and easy fix!
2003 Chevrolet Silverado 2500HD Ambulance (A51692)
2003 Chevrolet...
CAT JUMP BOX (A53843)
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2002 14ft S/A Utility Tilt Trailer (A51694)
2002 14ft S/A...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2009 Lincoln MKS Sedan (A51694)
2009 Lincoln MKS...
