new holland td95d
   / new holland td95d #1
dtubbs5
Mahtomedi, mn
new holland td95d
one of the rear final drives is leaking on my td95d & the seal needs to be replaced. the wheel & hub are off but how is the snap ring removed. can i use a pliers to take it off or does it require a special tool. also is installing the new seal straight forward or is there something i should know before taking it out.
thanks,
dennis
   / new holland td95d #2
Just wondering...Did you every find out the answer?
   / new holland td95d
ch1ch2
Never did find out about the seal but I don't think that was the problem. I resealed the hub & that took care of the leak but I have another problem. Having a hard time getting good brake pedal. I have the service manual on brakes, hydraulics etc. I've made adjustments & the left brake is much better but still goes down too far but the right brake needs to be pumped to get good pedal. I have bled the system & the brake reservoir was full to start w/so I don't think the axle seals are bad. Both pedals are the same height but after adjusting the links going to the axle the first time to the specified 190 mm & the parking brake there were no brakes, not even the park brake. I put the links back to where they were & readjusted the park brake & as I mentioned earlier have decent pedal on left side but not the right. Park brake also works. I did jack up each side of the tractor to make sure the brakes weren't dragging after adjustments. Fluid in the reservoir was a light green color which I read on other posts is what it should be but the hydraulic fluid from the New Holland dealer is clear. Service manager said the green fluid is factory & what they sell is the right fluid. Could the right discs be worn or does the right slave cylinder have a bad seal. If any brake was used more it normally is the left side. Maybe I don't have the adjustments correct. Guess I need some help.
Thanks,
Dennis
   / new holland td95d #4
Sorry to hear that.
I can't think of anything that would help.
Maybe there is someone out there that will have the answer. Sometimes it is just a matter of keeping the thread fresh enough for that someone to read it.
I see this is only your 3rd post. Welcome to TNT
   / new holland td95d #5
ch1ch2
Thanks,
Dennis
The brakes on my TD95D are spongy so I think I'll have to bleed the slave cylinder(s)r. I see no sign of a leaks so I figure that it was not bled at the factory. I don't have many hours on mine ( ~400) to have that much wear on the discs. Sounds like you bled yours with no effect.
   / new holland td95d #6
ch1ch2
Thanks,
Dennis
I looked at our TD95D brakes today since I was changing the engine oil and filter as well as greasing the front end. I can barely see the left side cylinder and I would have to drop the fuel tank to work on the left side of the braking system and adjust the clutch pedal. What a design! As near as I could tell there did not appear to be a bleeder screw on the left side slave cylinder but there must be a way to bleed it. Maybe I just could not feel it because of the clearance issues
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
