New Holland TD95D Hard Clutch
   / New Holland TD95D Hard Clutch #1
lynntatom
Cisco, Tx.
New Holland TD95D
Just purchased a 2007 TD95D New Holland tractor. Has front end loader and 4 wheel drive. Clutch is extremely hard to press. I thought at first that it was just my imagination but after running it for about an hour my leg was worn out. I have not picked up a manual yet and have not had time to look into the problem. Just wondering if anyone else has the same issue?
Lynn
   / New Holland TD95D Hard Clutch #2
I'm not familiar with that particular model. Surely someone who is, will be along shortly.
I did have a NH 7610S. (100 hp) It too was 4wd and mechanical clutch. If I worked it all day, I would have cramps in my left leg at night.
Not sure about the cross shaft. I don't have a manual yet so shooting in the dark. Plan to look at it more when I get home. In the Gulf of Mexico right now.
Thanks.
   / New Holland TD95D Hard Clutch #5
I have the same model with a cab but I have not had any problems with the clutch pedal. The clutch gives you a workout especially with a lot of loader work but it's smooth in operation. I'd check the linkage to make sure it's not damaged and as RickB says , check the shaft.
Thanks for the reply. I will look into the cable and linkage.
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
20711 (A51694)
20711 (A51694)
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
UNUSED FUTURE FT-X1200J STAND ON MUD BUGGY (A51247)
UNUSED FUTURE...
DESK (A53843)
DESK (A53843)
