New Holland TD95D Hard Clutch
   / New Holland TD95D Hard Clutch #1
lynntatom
Cisco, Tx.
New Holland TD95D
Just purchased a 2007 TD95D New Holland tractor. Has front end loader and 4 wheel drive. Clutch is extremely hard to press. I thought at first that it was just my imagination but after running it for about an hour my leg was worn out. I have not picked up a manual yet and have not had time to look into the problem. Just wondering if anyone else has the same issue?
Lynn
   / New Holland TD95D Hard Clutch #2
I'm not familiar with that particular model. Surely someone who is, will be along shortly.
I did have a NH 7610S. (100 hp) It too was 4wd and mechanical clutch. If I worked it all day, I would have cramps in my left leg at night.
Not sure about the cross shaft. I don't have a manual yet so shooting in the dark. Plan to look at it more when I get home. In the Gulf of Mexico right now.
Thanks.
   / New Holland TD95D Hard Clutch #5
I have the same model with a cab but I have not had any problems with the clutch pedal. The clutch gives you a workout especially with a lot of loader work but it's smooth in operation. I'd check the linkage to make sure it's not damaged and as RickB says , check the shaft.
Thanks for the reply. I will look into the cable and linkage.
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
JOHN DEERE CP690 LOT NUMBER 245 (A53084)
JOHN DEERE CP690...
