New Holland TD 95D, oil leak
   / New Holland TD 95D, oil leak #1
lildobr
Mt. Vernon,IL
Kioti DK35SE
Hello, A friend of mine has a N.H, TD 95 D that has a leak on the right side under the cab. It looks to me like it may be coming from whear the hydraulic control valves are sandwiched together . Oil seeps and drips on the right hand side three point arm whear it mounts to the tractor frame. He called and said it is getting worse now uzzing down the control arm to the end with arms down and dripping off. Does anyone else have experience with this problem? Looks to be a real p.i.a. to remove all the valves and reseal them. Does anyone know if it would be possible for oil to leak out where the arm attaches to the tractor? Its hard to tell exactly where it is coming from. Thanks For any help. Lildobr I don't have any pics sorry
   / New Holland TD 95D, oil leak #2
I can't see it too well from here. Clean it up good and check closely to see where the oil appears first. More likely to be from the valve stack or a line connection than anything else.
Update,
Problem was a seal on the three point pivot pin that runs thru the rear axle housing. It had grass and trash in it cleaned it up and put back together.Now we see if that fixed it only around 750 hrs on tractor and hardly any use on three point. Poor design, hope they changed this by now. Lildobr
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2011 Liebherr L586 (A53472)
2011 Liebherr L586...
2001 John Deere M665 (A50120)
2001 John Deere...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2015 Ford Taurus (A51694)
2015 Ford Taurus...
