New Holland TC48DA PTO will not disengage
   / New Holland TC48DA PTO will not disengage #1
rs2828
west end, nc
New Holland TC48DA
I just purchased a used TC48DA with 748 hours on it. Everything works great, loader lifts strong, drives, etc. no issues but the PTO will not disengage. The tractor had a new PTO clutch and hydraulic pump replaced at 430 hours so it shouldnt be the clutch. The linkage is hooked up and moves the hydraulic valve as it should (it appears) but it will not change. What and how should I check? Any suggestions? I've tapped on the PTO hydraulic valve with a hammer to see if maybe it was stuck but it did not change.
Today I finally got around to checking into this. I read the above thread and I just wanted to confirm before I either paid to repair or attempted myself. here are the details, please share your thoughts.
When the tractor is not running the PTO does not turn - even using a large pair of channel locks (safely protecting the splines) it barely moves.
When the engine is running and you engage the PTO you can hear a definite change in the pitch of the engine which leads me to believe that something is engaging.
I removed the hydraulic valve, inspected for proper operation and it appears to be working as designed. Using air, when rotating the valve redirects the air from one port to the next. I did find one oring that was not installed properly on the tubes going into the case.
I redirected the fluid from the hydraulic pump into a bucket, left the valve off, and started the engine for a mere few seconds and the PTO still spins (hydraulic pressure/valve completely out of the circuit)
I assume this means that the PTO Brake must be worn out like the other thread. I just dont understand why it doesnt free spin when the engine is not running. Is that brake supposed to put that much force to where, even as hard as it is to turn, its still not enough?
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
Wolverine Log Splitter (A50515)
Wolverine Log...
John Deere 1790 Planter (A50514)
John Deere 1790...
2006 CIMC SZJ9341TJZ03 20FT CHASSIS TRAILER (A52141)
2006 CIMC...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
