New Holland TC45DA hour meter repair/replacement
   / New Holland TC45DA hour meter repair/replacement #1
VOL54
NW Tennessee
New Holland TC45DA, John Deere 345
My TC45DA hour meter recently died. I'm assuming that the bottom access panel below the steering wheel would have to be removed to access the meter. Hopefully the upper panel containing the meter would not have to be removed. Until I can access the meter, I don't know if I have a bad/corroded connection or a bad meter. Any way to test this analog meter? Any thoughts or comparable experiences on this? Thanks.
   / New Holland TC45DA hour meter repair/replacement #2
Your tach is electrically driven from a wire from the rear of the alternator. Refer to this thread for more information.
   / New Holland TC45DA hour meter repair/replacement #3
Had the same issue on my TC45DA a while back — turned out to be a corroded connection behind the lower panel, so you're on the right track starting there. I didn’t have to remove the upper panel, thankfully.
2006 John Deere 120C Hydraulic Excavator (A53421)
2006 John Deere...
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2020 FREIGHTLINER...
2016 HAULMARK 24 ENCLOSED TRAILER (A55745)
2016 HAULMARK 24...
Suihe 20'x40' Container Shelter (A53316)
Suihe 20'x40'...
2002 Ford F-450 Lift-All LAH-30-15 30ft Bucket Truck (A55788)
2002 Ford F-450...
