Loader New Holland TC45DA frontloader problem, won't raise or lower
   / New Holland TC45DA frontloader problem, won't raise or lower #1
provobis
NE Ohio
TC45DA
From the beginning, I began to use the TC45 this morning by moving some dirt with the 16LA frontloader to another spot. everything went well until after I dumped the dirt and lowered the bucket to ground level. At that point the loader would not raise or lower, though the hydraulics seem to be straining the hoses, but the loader acts like it's locked in place at ground level. I can still rotate the bucket in or out but not up and down. I have checked all fluids, stopped and started the tractor again but still have this problem. Never had this problem before or anything like it, The rig is 7 years old. Help! :confused:
   / New Holland TC45DA frontloader problem, won't raise or lower #2
Assuming your other hydraulic's are functioning I'd say it's probably going to be solved by disconnecting and reconnecting your quick connects to the loader.
Brian
Assuming your other hydraulics's are functioning I'd say it's probably going to be solved by disconnecting and reconnecting your quick connects to the loader.
Brian
.....or more precisely ".......reconnecting your quick connects to the loader". While I was hoping for a response from anyone here, I went out again and more closely inspected everything. I really am getting old, because I had missed a hydraulic male hose fitting that had popped out of its female receptacle. After relieving pressure by cycling the loader joystick with the engine off I reinserted the hose fitting (which popped out again in operation) so I put it back a second time. It seems to be holding now but I suspect that I'll need to replace the fittings on that hose (or that hose entirely) with new ones that will hold under pressure. Don't know why it took 7 years for the fittings to give out since they aren't moving parts and don't really wear. What do you think? And thanks for the comeback Brian.... in any case I think this particular problem is answered and solved. :)
   / New Holland TC45DA frontloader problem, won't raise or lower #4
Excellent,and welcome to TBN from New Hampshire.
Brian
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
