New Holland TC45D won't start fuel supply issue
   / New Holland TC45D won't start fuel supply issue #71
When the key is on the "run" position is there power to the solenoid? How about in "Start" position? "off" position? Does the solenoid move when you change key positions?
   / New Holland TC45D won't start fuel supply issue #72
OMG!!! It started for the first time in a couple of weeks and it is running as I type.
I jumped the solenoid to the battery and I started right up
So what am I chasing now??
Thank ya'll SOO much
   / New Holland TC45D won't start fuel supply issue #73
Should the solenoid click I key is just on? Or cranking?
   / New Holland TC45D won't start fuel supply issue #74
Bad relay, fuse or wiring between the key switch & the fuel shut-off solenoid.
   / New Holland TC45D won't start fuel supply issue #75
The solenoid should allow fuel into the injector pump when you are running & stop it when you turn the key off. SO ... you want it powered when in start or run and depowered in "off"
   / New Holland TC45D won't start fuel supply issue #76
Thank you!! Will it hurt to run it with the solenoid jumped to the battery. I need to get this in to service for a couple of days.
   / New Holland TC45D won't start fuel supply issue #77
Long as you have an easy way to disconnect the jump to shut her down, you should be ok ... just make sure whoever is working on it knows what needs to be done to turn the tractor off quickly & reliably. If you have a toggle switch that you can insulate & tuck out of the way but handy, that may work until you trace down the wiring issue.
   / New Holland TC45D won't start fuel supply issue #78
Some solenoids use a different holding circuit to minimize heat. I don't believe your solenoid is that type.
For some reason you are not getting power to your fuel solenoid when you turn the key. This may be a bad relay or something in your safety circuit (seat presence, not in gear, brake on, PTO not engaged...)
   / New Holland TC45D won't start fuel supply issue #79
I will be the only one working on it (and under it) Book says the number 2 slot is an 8a breaker. Swapped it for a 10a fuse and cranked it. Fuse intact but no start.
   / New Holland TC45D won't start fuel supply issue #80
Connect the solenoid wire to a trouble light and it will be easier to trouble shoot. Do you have a service manual or wiring schematic for her. I would guess it uses a relay but it could be just wired.
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
KENMORE ELITE REFRIGERATOR/FREEZER COMBO (A51248)
KENMORE ELITE...
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
