New Holland TC45d Hydraulic Adapter Plate questions
   / New Holland TC45d Hydraulic Adapter Plate questions #1
skinnr
I am carrying this over from the New Holland forum. I have a NH TC45d that I purchased in a few pieces but that is another post. I have been running it now for a few years and need to add a rear remote. I have a Bradco backhoe that I use on it and get my power from the Power Beyond on my loader valve. Works just fine. With my box of pieces came this adapter plate that I never did install. It is suppose to mount on the side of the 3 point lift and is looks like a way to get flow directly off the lift to supply the backhoe or another attachmant. My question is where do the three ports go? They are labled P , R, and T. Rather than replumb the backhoe I want to add a few valves back there for "rear remotes" but not sure which is which. Captain Obvious tells me P is pressure, R is return and T may be tank. But wouldn't tank and return be the same? NHTC45(a).JPGNHTC45.JPGNHTC45(b).JPGNHTC45(c).JPG Kinda stuck and looking for ideas. Thanks
OK I figured it out. The local tractor mechanic is familiar with this part and set up. P= Pressure to the spool valve. R= return from the spool valve. T=tank/ plumb it out from the block and go back to the tank for an overflow situation. He said that landscapers use this set up alot to power up a set of valves to run specialty equipment for fine adjustments for grading/ slope etc. He said it is an acceptable workaround for rear remotes and allows for finer adjustments. I'll let everyone know how it works out.
2020 Kubota BX2380 (A50120)
2020 Kubota BX2380...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
