New Holland TC35 Will Not Start
   / New Holland TC35 Will Not Start #1
Ghost River Retrievers
Benton County, MS
New Holland
Yesterday I was moving some dirt around to make a mound a bit lower and less steep. Everything was going smoothly and I was nearly done when I decided that I needed to take a view from the top of the mound. So I stopped the tractor, lowered the bucket, put the shifters into neutral position, reduced the RPM to lowest possible setting, and set the brake. Of course, I've gone thru the same process innumerable times. But this time when I raised my rear off the seat, the engine shut down. "No problem," I thought.
So after viewing my handiwork and seeing a few spots that needed a bit more sculpting, I climbed back on the tractor, put on my seatbelt, turned the key partway to warm up the glow plugs, waited for the light to go out, turned the key to start it ... NOTHING HAPPENED. So my initial thought was wrong ... there IS a problem.
So where do I look first? (The on-line "yellow pages" will be the second or third place that I look.)
At first I suspected the seat switch, but then it seems to me that it wouldn't have been running in the first place. I suspect that a safety switch somewhere is telling the tractor that it shouldn't start/run because it's in gear ... does that make sense?
How do I figure out if it's the "in gear" safety switch?
Where else should I look and what else should I consider?
FWIW, the battery is brand new and is fully charged.
Thanks for any help!
GRR
   / New Holland TC35 Will Not Start #2
Not sure if you have a clutch or HST. if HST, it could be the "neutral" position switch is not adjusted or the pedals need adjusting before it will start.
I can start my LS with the brake set and range selector in N without being in the seat. I usually start it this way standing beside the tractor so it has a couple minutes to warm up and I can do other things, like open the gates, etc.
If a gear, then maybe the neutral switch if it has one or the brake switch are the only 2 I would think could cause this. Did you try shifting gears and back to neutral?
Edit: PTO didn't get switched on did it?
Good luck.
I can start my LS with the brake set and range selector in N without being in the seat. I usually start it this way standing beside the tractor so it has a couple minutes to warm up and i can do other things.
good luck.
It's got a clutch, so maybe the brake switch or neutral switch.
Thanks for your suggestions!
GRR
   / New Holland TC35 Will Not Start #4
for one if you have been using it you wont need to use the glow plugs to start it again.
another possibility for no start ...battery or terminals
   / New Holland TC35 Will Not Start #5
You got off the seat. The tractor died. That sure sounds to me like the seat switch MAY be the culprit. Check it out as well as any nearby wiring for broken or bad connections.
   / New Holland TC35 Will Not Start #6
When I have an issue like this I cycle all the levers and pedals, then put all in a position to start, brake set, transmission in neutral, etc. I have moved the PTO lever getting on or off just enough so it would not start.
Thanks for the suggestions!
I'm heading out now to check things over and will report back.
GRR
GRR
Dang-it! I looked at and messed with the seat switch, pto switch, clutch switch and break switch ... they all look fine. I also cycled through the levers and pedals several times, trying to start it throughout the process.I didn't have time to check the switches by by-passing, but hopefully I'll have time to do that tomorrow.
GRR
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2019 Chevrolet Tahoe SSV 4WD SUV (A55758)
2019 Chevrolet...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
