NEW HOLLAND TC33D
   / NEW HOLLAND TC33D #1
qed-cat225
Sullivan, WI
2011 Bobcat CT235
What is the breakdown of the various "classes" of the TC line? Is the 2000 TC33D now the TC34DA or the TC35 size? does anyone have a side view side by side of the TC33 and the TC35DA so I can see the size difference?
   / NEW HOLLAND TC33D #2
TC33 is now the TC34... rumer has it they tweeked injection pump pressures to squeeze another HP out on paper or something stupid like that to "keep up with the jone's"
they are simular in all aspects (cept cosmetic hoods etc that were changed in within the past few years.
The TC35 is a class 3 machine, its the same size as the TC40/45/55 but with a wus of an engine.
TC35 is larger in most/all aspects than the TC33 just like the 40/45 is.
clear as mud?
   / NEW HOLLAND TC33D #3
Current Models:
Boomers:
Class I - TC23DA, TC26DA
Class II - TC31DA, TC34DA
Class III - TC35DA, TC40DA, TC45DA.
The tractors within the same class will have the same frame, but will have different engines or ratings for higher horsepower. The TC33 would be a Class II machine, which is significantly different from the TC35 Class III machine.
The TC48DA and the TC55DA are listed under the "Utility" Tractor line.
   / NEW HOLLAND TC33D #4
msiewert96:
The TC29DA became the TC31DA after it got "tweaked" and is considered by NH to be a Class II tractor which is their midsize CUT frame size. I believe the "old" NH Class II TC's included the 25, 29, and the 33. I believe that any smaller framed tractor was considered to be their ClassI. It is important to note that I believe that only NH designated "classes" for their tractors based on frame size. Jay
   / NEW HOLLAND TC33D #5
The "TZ" series of compacts are clasified as class "0" by New Holland.
   / NEW HOLLAND TC33D #6
or like the bota BX series "overgrown riding lawn mowers" ;)
   / NEW HOLLAND TC33D #7
Isn't that a blue, overgrown lawnmower to the left of your comment?
Meant in fun :D
   / NEW HOLLAND TC33D #8
TC 33 was replaced with TC34; the TC 34 has the TC 35 engine in it; to avoid confusion they called it a TC34. These TCxx numbers will begin to disappear shortly as New Holland begins the change over to a new (old?) numbering system.
   / NEW HOLLAND TC33D #9
What the new (old) numbering system? 4 digit thousnd series? ( I liked that one.. you knew what series you were dealing with.. and what base model , usually by 1st and 3rd digit. and last digit gave you some idea of extra bells and whistles or lack thereof..
Soundguy
   / NEW HOLLAND TC33D #10
Meant in fun :D
why yes it is.. :D (but still twice the size of a sub-compact)
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
(1) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(1) UNUSED 7000#...
