New Holland TC30
   / New Holland TC30 #1
jand38
Texas "Brazos Valley"
New Holland TC 30
Any TC30 owners forget and leave parking brake on or just me? Has any one came up with a warning light or some way to help one remember to disengage the brake before driving? I sure would appreciate any solutions you may have.
   / New Holland TC30 #2
My solution was to get a boomer. It has the light. You should be able to adapt the boomer series light system to your TC 30. Switch and a light will do it. ( wire too!)
   / New Holland TC30 #3
Yep.. I used to load test my parking brakes on my NH 1920 all the time... have done so on my 5000 as well...
Soundguy
   / New Holland TC30 #4
Soundguy
Makes me laugh. Of course I find out that way on my 2120. What's the big deal. Just release it when you notice it and worry about something important.
Andy
   / New Holland TC30 #5
My TN with cab has a lever that sticks up. A light on the dash and a beeper that squaks. sometimes I still try to go with it on. I always notice it and release it.
Andy
   / New Holland TC30 #6
I am a noob at this so I try to do the same routine every time I start up.
It's something like this;
Buckle in
Engage brake and clutch <releases parking brake
Check both shifters to ensure they are in neutral. ( I know not totally necessary but I do both anyway.)
Turn key until glow plug light glows and count to 5
Start tractor
Fire up big grin and go play
   / New Holland TC30 #7
I have a light and it still gets ignored.
   / New Holland TC30 #8
The secret is to apply the brake firmly enough to actually hold the tractor stationary. Then when you drive off with the brake applied, the engine either stalls outright, or loads significantly enough that even a novice operator will figure out what is amiss right away.
   / New Holland TC30 #9
That may work on SCUT.. or small CUT's... I havn't found a good UT or AG tractor that brakes made any difference on if you didn't have the clutch pushed. The brakes on my 5000 and 7610 are plenty good enough to lock the axle and skid the tire with the clutch dumped.. but put it in gear at anything above idle and the tractor will walk off without much complaint at all.. ( my 1920 would walk off as well... but it complained enough to let you know that you were load testing the brakes and polishing the drum/disc.. etc.. ) ;)
Soundguy
   / New Holland TC30 #10
I live on a hillside, quite literally. If I didn't set the parking brake *every* time I got off the tractor, I'd be running after my tractor a lot more than I do now. (Yeah, every once in a while I still forget. You oughta see me jump back into that seat!)
When I set the parking brake, I have to push very hard on the pedal to get it to lock and not move. We are talking putting all my weight on it and shoving against the seat. I *can* set the parking brake one notch lower, and the tractor will still move on me (refer to above and jumping back into seat).
When I have the parking brake properly set, the engine will not move the tractor. I have HST, and it just sits there...
There should be a brake adjustment *and* a parking brake adjustment linkage.
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
