New Holland TC29da won't start?elp
   / New Holland TC29da won't start?elp #11
The battery ground cable is known to corrode at the frame. I'd remove it and wire brush things real well to be sure. And it may seem simple...but did you charge up the new battery?
Edit - I see Navasot beat me to it.
   / New Holland TC29da won't start?elp #12
The first thing that you said leads me to believe that it's the dreaded ignition switch issue that plagued these tractors. I cooked two switches and had the same exact issues that you did before I installed the relay. Read the linked thread and that should get you going in the right direction. It's a relatively easy and inexpensive project that seems to fix a lot of the issues.
http://www.tractorbynet.com/forums/...ting/127106-dx-33-starting-problem-fixed.html
Good luck and hope this helps!
2011 CAT 430E BACKHOE LOADER (A50854)
2011 CAT 430E...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
71065 (A49346)
71065 (A49346)
2005 John Deere 824J Articulated Wheel Loader (A49461)
2005 John Deere...
2011 FORD F-450 (A50854)
2011 FORD F-450...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
