New Holland TC25D rear 3pt arms not moving?
   / New Holland TC25D rear 3pt arms not moving? #1
Pipewelder76
Kenmore, NY and Cuba, NY
Kubota B7100 and NH TC25
Hello all. I went to install an implement yesterday and found that the rear arms are not moving. It has a float position. There is a FEL on it and it's working properly. Used the tractor 2 weeks ago without any troubles. I'm stumped. Any help or suggestions would be greatly appreciated. Thx and God Bless.
   / New Holland TC25D rear 3pt arms not moving? #2
If the arms are stuck in the UP position, and not lowering, check the rate of descent knob below the front of the seat. Turn it counterclockwise to allow the arms to lower. If the arms do not raise, check the FEL lever and confirm it is not in the float position.
Thx for the reply. My daughter was playing around on the tractor and may've fooled with it. I'll definitely check it out. Thx again.
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
CAT D4G LGP (A47384)
