New Holland TC18 3pt hydraulics
   / New Holland TC18 3pt hydraulics #1
jwfordracing
New Holland TC18
After I took off the bucket loader, I tried using the 3pt. The 3pt went down but then wont go back up. It wont go up or down. It's full of fluid, steering works and it drives fine. Any help would be greatly appreciated! Thanks in advance.
   / New Holland TC18 3pt hydraulics #2
Turn the slotted head valve spool in the diverter valve 90 degrees. The valve is located below and in front of the brake pedals.
Do not operate your tractor until this is resolved. Severe hydraulic pump damage WILL result.
What causes it to do that? Will I know if it worked with the tractor not running? Do I have to do this every time I put the loader on or take it off?
   / New Holland TC18 3pt hydraulics #4
Move the valve then start the tractor and check the 3pt immediately. Depending on how the loader is connected, yes you will need to do this every time. I am making the assumption the the hydraulic system is deadheaded because the open center circuit is incomplete.
This is the diverter, I turned the slotted head counterclockwise. I have not started it up yet. 20190505_064149.jpg
That worked! Thank you so much!!
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A51039)
2015 Ottawa Yard...
2021 Snake River 14K Dump Trailer (A49461)
2021 Snake River...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
